check_esx3.pl output truncated in Nagios/ CPU Load
rajasegar
Re: check_esx3.pl output truncated in Nagios/ CPU Load
Post by rajasegar »
scottwilkerson wrote:
Box293 wrote:To fix the truncated output we need to increase the size of the tables in Nagios XI.
Execute the following commands at the CLI:
    echo "use nagios;alter table nagios_servicestatus modify output varchar(65535) not null;alter table nagios_servicestatus modify long_output varchar(65535) not null;alter table nagios_servicestatus modify perfdata varchar(65535) not null;" | mysql -pnagiosxi
    echo "use nagios;alter table nagios_hoststatus modify output varchar(65535) not null;alter table nagios_servicestatus modify long_output varchar(65535) not null;alter table nagios_servicestatus modify perfdata varchar(65535) not null;" | mysql -pnagiosxi
    echo "use nagios;alter table nagios_servicechecks modify output varchar(65535) not null;alter table nagios_servicestatus modify long_output varchar(65535) not null;alter table nagios_servicestatus modify perfdata varchar(65535) not null;" | mysql -pnagiosxi
    echo "use nagios;alter table nagios_hostchecks modify output varchar(65535) not null;alter table nagios_servicestatus modify long_output varchar(65535) not null;alter table nagios_servicestatus modify perfdata varchar(65535) not null;" | mysql -pnagiosxi
The next time the check is executed the output will not be truncated in the XI interface.
As for the high CPU load, I recommend what slansing said and implement the box293_check_vmware plugin / solution as it offloads the plugin to a vMA appliance.
As an FYI, this code does have a slight bug in it and should read
echo "use nagios;alter table nagios_hoststatus modify output varchar(65535) not null;alter table nagios_hoststatus modify long_output varchar(65535) not null;alter table nagios_hoststatus modify perfdata varchar(65535) not null;" | mysql -pnagiosxi
echo "use nagios;alter table nagios_servicechecks modify output varchar(65535) not null;alter table nagios_servicechecks modify long_output varchar(65535) not null;alter table nagios_servicechecks modify perfdata varchar(65535) not null;" | mysql -pnagiosxi
echo "use nagios;alter table nagios_hostchecks modify output varchar(65535) not null;alter table nagios_hostchecks modify long_output varchar(65535) not null;alter table nagios_hostchecks modify perfdata varchar(65535) not null;" | mysql -pnagiosxi
Or slightly cleaner
echo "
alter table nagios_servicestatus modify output varchar(65535) not null,modify long_output varchar(65535) not null,modify perfdata varchar(65535) not null;
alter table nagios_hoststatus modify output varchar(65535) not null, modify long_output varchar(65535) not null,modify perfdata varchar(65535) not null;
alter table nagios_servicechecks modify output varchar(65535) not null,modify long_output varchar(65535) not null,modify perfdata varchar(65535) not null;
alter table nagios_hostchecks modify output varchar(65535) not null,modify long_output varchar(65535) not null,modify perfdata varchar(65535) not null;
" | mysql -pnagiosxi nagios
Thanks. I will try it out.
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
