newlines in JSON
jssingh
Re: newlines in JSON
Post by jssingh »
Sorry, I was out on Friday and forgot to bump. =(
abrist
Red Shirt
Post by abrist »
That's fine. So was Eric :P
I will attempt to get more information through email instead.
droland
Post by droland »
Hi, I'm jjsingh's coworker and will be tracking this issue while she is out of the office.
I would appreciate it if you can add me to any email traffic.
David
abrist
Red Shirt
Post by abrist »
You may need to subscribe to this thread to receive emails. Eric[0] just committed and pushed code late last week. All standard JSON escaping should now be implemented in the json cgis.
jssingh
Post by jssingh »
first a note on personnel. I will be intermittently out of the office quite a bit until labor day, so (as mentioned earlier) David will be following up on things while I'm gone, but I will be popping in here now and then as well.
Thanks for the update and I installed the latest commit ... but now the JSON breaks for the services with newlines:
from the browser I get an Internal Service Error.
from a script on the command line I get this error:
-bash-4.1$ ./qstat_test.pl
, or } expected while parsing object/hash, at character offset 574 (before "\n") at ./qstat_test.pl line 13
-bash-4.1$
I looked at the output from the original plugin and the character at 574 seems to be where a newline should be. Let me know if you need any more information before I revert back.
abrist
Red Shirt
Post by abrist »
Could you post (obfuscate where necessary) the status string that is failing? (particularly he few chars before and after the offset?)
jssingh
Post by jssingh »
from the plugin output:
 Server reports 3 jobs total (T:0 Q:0 H:0 W:0 R:3 E:0 B:0)\\n\\n  Host       CPUs Tasks Jobs Info\\n  ---------- ---- ----- ---- ------------------\\n   243 hosts 1944     0   -- har\\n  r710i1n15     0     0    0 har down\\n   370 hosts 2960  2960   -- har in-use\\n    25 hosts   40     0   -- har offline\\n  r719i0n6      8     0    0 har {offline down}\\n\\n                                          Req'd     Elap\\nJobID      Queue  Jobname        CPUs Nds wallt Ss wallt Eff Group Model\\n---------- ------ -------------- ---- --- ----- -- ----- --- ----- -------\\n13170.p233 long   RS25VoF         800 100 16:00 R  00:12 28% e1120 100:har\\n   Job run at Mon Jul 21 at 09:59 on (r704i0n10:ncpus=8)+(r704i0n11:ncpus=...\\n13171.p233 long   MLHoleVoF       800 100 16:00 R  00:08 11% e1120 100:har\\n   Job run at Mon Jul 21 at 10:03 on (r707i1n2:ncpus=8)+(r707i1n3:ncpus=8)...\\n13167.p233 normal tnksmthlwr4o6H 1360 170 08:00 R  02:45 86% e1201 170:har\\n   Job run at Mon Jul 21 at 07:24 on (r701i0n1:ncpus=8)+(r701i0n3:ncpus=8)...
character 574 is the newline here:
hope this helps.
What is your perl version?
perl -V | head -1
I found a somewhat recent bug with older versions of perl parsing JSON resulting in that same error:
https://github.com/makamaka/JSON-PP/issues/8
It might still be a lingering issue worth looking into.
In addition, can you pipe the plugin output to a file and attach that file? I want to look at it from a hex level.
droland
Post by droland »
Here is the perl version:
droland@lnxsrv78:~> perl -V | head -1
Summary of my perl5 (revision 5 version 10 subversion 1) configuration:
Janice is expected back later this week. She will have to prepare and send the file.
David
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Sounds great, either pm it to tmcdonald or paste it here and he will take a look!
