EDIT: Test initiated. I fought through the sluggish system
CPU Load Spike daily
Re: CPU Load Spike daily
This is a "test" system as I couldnt release this to the wild with this issue. So I will attempt this fix and report back tomorrow. The machine is unusable right now as we are in the spike window. I will get you the nagios.cfg and PM it to you as requested.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
I left nagios off for 6 minutes and it is now 10+ minutes after I turned it back on and still seems spread out ok. System is usable as well. True test will be 12:30CST tomorrow, I'll report back then.
Excellent! We look forward to hearing tomorrow, thanks for checking back in!
Like clockwork the load spike just started.
Maybe that was just a small spike, it went back down. I know as soon as i type this it'll go back up again....just ignore me, I'll report back in an hour.
Ok, its 30 minutes into the spike window and I can say it seems ok. However, after applying that scheduling patch yesterday, look at this:
Service is setup for 5 minute check intervals but scheduler gave it 10 mins: After those 10 minutes, this time it gave it 6 minutes: EDIT: The ones scheduled for hourly are even way worse. Anywhere between 15 and 40 minutes the next check gets scheduled for.
And now I just want to give up. Seems after a week straight of the spike starting at 12:30CST today it magically started at 13:30CST. Server is unusable for past 20 minutes. I'm sure if I stopped nagios for a few minutes it'd be fine until tomorrow.
Eric[1] is working diligently on this issue. I will make sure to pull him into this topic.
Thanks Andy.abrist wrote:Eric[1] is working diligently on this issue. I will make sure to pull him into this topic.
Just to update, here is today's perf graph. FYI - Displaying EST times as I am currently in Ohio
It wasn't nearly as long as the previous 7 days, and not even as long s it looks like it was in this graph since rrd averages over time. But there were a couple large spike that made the machine unusable for 10-15 minutes each. So it did get better with applying that schedule patch, just not 100% better. But then there is the scheduling time and they are just way to off. There are items I need checked every 5 minutes, that is why they are set that way, if it doesn't get checks for 10 minutes instead it could cost customers money. And for the 1 hour scheduled stuff, some are looking for files that are only present once per hour, so it it checks short, then it'll always error out. So in short, the new scheduling is not good at all*except for the load easing).
I have a suspicion that commit will get reverted . . . .BanditBBS wrote: So in short, the new scheduling is not good at all*except for the load easing).
More on this soon as Eric[1]'s work progresses. . . .
Update: as of 9am CST I have been at double digit load for 25 minutes and counting. I'm going to kill the nagios process and le tit sit for a few minutes just so I can use the server.
