Guide for installing 4.0.7 on Ubuntu 14.04
emislivec
Re: Guide for installing 4.0.7 on Ubuntu 14.04
Post by emislivec »
shaunie1975 wrote:I ran the ./configure as
./configure --with-command-group=nagcmd --with-httpd-conf=/etc/apache2/conf.d
which didnt work...
Looks like I told you the old directory: https://help.ubuntu.com/14.04/serverguide/httpd.html
conf-available: this directory contains available configuration files. All files that were previously in /etc/apache2/conf.d should be moved to /etc/apache2/conf-available.
Sorry about that. So in the future we should be able to do it automatically with:
./configure --with-command-group=nagcmd --with-httpd-conf=/etc/apache2/conf-available
shaunie1975 wrote:Now when I login I see the nagios core and the logo then below that i see a red X and not running next to it.
This probably means the Nagios server isn't running. We can check that with:
[root@core]# service nagios status
No lock file found in /usr/local/nagios/var/nagios.lock
This tells us Nagios isn't running. Then to start it:
[root@core]# service nagios start
Starting nagios: done.
nagios (pid 6224) is running...
With chkconfig installed you can check that Nagios is set to start automatically:
[root@core]# chkconfig --list nagios
nagios          0:off   1:off   2:on    3:on    4:on    5:on    6:off
If it's not set to start automatically, we can change that with:
chkconfig --add nagios
