Nagios 2240 + Check-Nagios-NG.pl + Configuration
futurist71
Re: Nagios 2240 + Check-Nagios-NG.pl + Configuration
Post by futurist71 »
After fixing the correct Perl version, it is working now.
Now for NetApp, on the Host Group Summary Status, it says PENDING, it doesn't change even all the commands are OK with GREEN status.
How can I fix that?
Regards,
Does the host group say pending? Or is this for the NetApp host itself?
Please post a screenshot.
futurist71
Here you have.
It's happening with Netapp and ESXi. Even when the commands are running on the right way.
http://imgur.com/S65u9De
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Those are specific to the host definitions you created. Essentially it looks like they have never run a check so nagios does not know their current status. This is because hosts and services are checked separately, so just because a service check returns, it does not effect the host status. Could you post the host configurations for those two objects and we can take a look?
futurist71
# ESXI HOSTS
define host {
use generic-host ; Inherit default values from a templ$
host_name ESXI00 ; The name we're giving to this host
alias ESXI00 ; A longer name associated with the host
address X.X.X.X ; IP address of the host
hostgroups esxi-servers ; Host groups this host is associate$
max_check_attempts 5 ;
define host {
host_name ESXI01 ; The name we're giving to this host
alias ESXI01 ; A longer name associated with the host
define host {
host_name ESXI03 ; The name we're giving to this host
alias ESXI03 ; A longer name associated with the host
# ESXI SERVICES
# Check DELL Server hardware
host_name ESXI00
service_description Hardware
check_command check_esxi_hardware!root!P@ssw0rd!dell
host_name ESXI01
host_name ESXI03
### ESXI00 ###
# Define a service to "ping" the local machine
host_name ESXI00
service_description PING
check_command check_ping!100.0,20%!500.0,60%
# VMWare
# check cpu
host_name ESXI00
service_description ESXi CPU Load
check_command check_esx_cpu!80!90
# check memory usage
host_name ESXI00
service_description ESXi Memory usage
check_command check_esx_mem!80!90
# check net
host_name ESXI00
service_description ESXi Network usage
check_command check_esx_net!102400!204800
# check runtime status
host_name ESXI00
service_description ESXi Runtime status
check_command check_esx_runtime
# check io read
host_name ESXI00
service_description ESXi IO read
check_command check_esx_ioread!40!90
# check io write
host_name ESXI00
service_description ESXi IO write
check_command check_esx_iowrite!40!90
### ESXI01 ###
host_name ESXI01
# VMWare
# check cpu
host_name ESXI01
host_name ESXI01
# check net
host_name ESXI01
host_name ESXI01
# check io read
host_name ESXI01
# check io write
host_name ESXI01
### ESXI03 ###
host_name ESXI03
# VMWare
# check cpu
host_name ESXI03
host_name ESXI03
# check net
host_name ESXI03
host_name ESXI03
# check io read
host_name ESXI03
# check io write
host_name ESXI03
sreinhardt
That would do it, so you have the hosts defined, and they should work fine, but you have no check intervals and no check commands defined in there. Some of this might be defined in generic-host template, if you want to post that we can look over it as well. But technically you have done nothing wrong here, just that without those configured the hosts never actually get checked.
futurist71
Now it's OK. I just defined the check PING command when declaring the host.
Thanks in advance, but...
I haven't finished yet.
Do you have some documentation about implementing Nagios notifications with Office 365?
Regards,
I don't believe so, but you can try searching Nagios Exchange for tutorials/how-tos on the topic. I found a post that might point you to the right direction:
http://www.telnetport25.com/2012/02/con ... gios-core/
sreinhardt
Unfortunately we do not, however either sendmail or postfix should be able to send out to a relay or smtp receiver for o365 just like any other mail server.
