NRPE:Unable to read output
- snapon_admin
Re: NRPE:Unable to read output
Same problem.
Is the disk full? It is really odd as it builds the check_nrpe bin just fine, and then immediately has a stat error . . .
- snapon_admin
Nope. Plus, you should know by now, I'm famous for my "odd" issues.
[root@nagiosTEST nrpe-2.15]# df -h
/dev/mapper/VolGroup-lv_root
97G 30G 63G 32% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
/dev/sda1 485M 50M 410M 11% /boot
Let's try to get some more info. Run the following commands:
then post the three files, that were generated from running the above commands in the /tmp (configure.txt, make.txt, and make-install.txt).
./configure --enable-command-args | tee /tmp/configure.txt
make | tee /tmp/make.txt
make install | tee /tmp/make-install.txt
- snapon_admin
Attached.
It *looks* like it made it this time. Let's find out:
ls -l /usr/local/nagios/libexec/check_nrpeFormer Nagios employee
- snapon_admin
It definitely does look like it took it that time.
But, it's still showing the "Unable to read output" alert as warning and not unknown. Here is my modifications to nrpe.c. Note, the line that needed to be changed wasn't on line 1389, but line 1370.
-rwxrwxr-x 1 nagios nagios 76769 Jul 21 16:14 /usr/local/nagios/libexec/check_nrpeCode: Select all
else if(!strcmp(buffer,"")) {
snprintf(buffer,sizeof(buffer)-1,"NRPE: Unable to read output\n");
result=STATE_UNKNOWN;
What version of nrpe are you running?
- snapon_admin
The one that I just downloaded to modify is 2.15.
Dang, I might have been testing on a local branch of the source. I will test this change on a virgin 2.15 clone.
