Performance graph not showing in service detail page
ssa_nagios
Re: Performance graph not showing in service detail page
abrist... I am not using gearman
Are you having issue only with highcharts? Can you see the image if you switch to the "old style" graphs?
Admin->Manage System Config->clear the "Use Highcharts for Perfdata Graphs" checkbox, and click on "Update Settings"
ssa_nagios
Yes it appears to be an issue with highcharts. After unchecking that option the graphs appeared again. How do I fix the highcharts option as I would prefer to have them instead of the old ones
Try installing the new, patched version of the Graph Explorer. This should fix your issue. You can follow the steps, outlined in this post:
http://support.nagios.com/forum/viewtop ... ge#p107179
ssa_nagios
Ok I have installed the updated version of graphexplorer and the Highcharts are now working again. But in the /var/log/httpd/error_log I'm getting a lot of php Notices:
Any suggestions on how to resolve these?
[Thu Aug 07 14:56:13 2014] [error] [client ] PHP Notice: Undefined variable: no_hover_fill in /usr/local/nagiosxi/html/includes/components/graphexplorer/templates/perfdata.inc.php on line 180, referer: http://********************/nagiosxi/perfgraphs/
[Thu Aug 07 14:56:13 2014] [error] [client ] PHP Notice: Undefined offset: 1441 in /usr/local/nagiosxi/html/includes/components/graphexplorer/templates/perfdata.inc.php on line 53, referer: http://********************/nagiosxi/perfgraphs/
[Thu Aug 07 14:56:13 2014] [error] [client ] PHP Notice: Undefined variable: no_hover in /usr/local/nagiosxi/html/includes/components/graphexplorer/templates/perfdata.inc.php on line 126, referer: http://********************/nagiosxi/perfgraphs/
[Thu Aug 07 14:56:13 2014] [error] [client ] PHP Notice: Undefined variable: no_hover_fill in /usr/local/nagiosxi/html/includes/components/graphexplorer/templates/perfdata.inc.php on line 180, referer: http://********************/nagiosxi/perfgraphs/Re: Performance graph not showing in service detail page
Well, they are not errors, just warnings. I will open an internal bug fix nonetheless.
ssa_nagios
Thanks abrist!!
np. I am locking the thread. Keep an eye on the next few release notes/changelog for the fix!
Update: resolved in 2014R1.4
