I had 57 folders in that directory. Shouldn't there be only one folder/directory per daily backup? If so, then 57 folders clearly violates the only keep 7 setting in my screenshot.
Otherwise, I'm still not catching on.
out of space!
Re: out of space!
So you have 57 folders in /store/backups/nagiosxi/ ? Or in the nom directory?
devildog31415
Re: out of space!
I had 57 folders in:
I already deleted them (so I could be wrong on number it was well over 40 and less than 60). before I ran the command to get rid of old directories:
find /store/backups/nagiosxi/ -type d -mtime +4 -exec rm -rf "{}" \;Re: out of space!
Many of those could have been hold overs from be fore the upgrade. The scheduled backup component does not remove any of the preexisting directories.
devildog31415
Re: out of space!
Will monitor moving forward. Please close this thread and I will review the folder in 4 more days to see if an 8th/9th day directory does NOT remove and can start a new thread.
Thank you
Thank you
Re: out of space!
Fantastic, cheers.
