Respond URL - Bad Ticket
BanditBBS
Re: Respond URL - Bad Ticket
Post by BanditBBS »
Ok, getting the error quite frequently apparently. If you'd like to investigate lets do it :)
This is our service desk that creates a ticket and then acknowledges alerts, so kind of a pain in the butt with rr not working for them.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Do we know if this is happening with all users attempting to use rapid response links? Also just to get it out of the way, XI version on that system? Let's also run the following:
grep 'secure_response_url' /usr/local/nagiosxi/html/config.inc.php
BanditBBS
Post by BanditBBS »
sreinhardt wrote:Do we know if this is happening with all users attempting to use rapid response links? Also just to get it out of the way, XI version on that system? Let's also run the following:
Sorry, this is on teh 2014 1.4 Server. This is not happening for all users as I just checked with some of the notifications I have received(not for same host/services though).
Secure response URL is remarked out, I did not enable that here:
// $cfg['secure_response_url']=1;
This is gonna be gross, but bear with me:
echo "select backend_ticket from xi_users where user_id=51" | psql -t nagiosxi nagiosxi | tr -d ' ' | tr -d "\n" | md5sum
BanditBBS
Post by BanditBBS »
tmcdonald wrote:This is gonna be gross, but bear with me:
[root@iss-chi-nag05 shapes]# echo "select backend_ticket from xi_users where user_id=51" | psql -t nagiosxi nagiosxi | tr -d ' ' | tr -d "\n" | md5sum
9c12089a0ee5c6da4f7575d700e3c185  -
Edit /usr/local/nagiosxi/html/rr.php around line 68 and add in the following:
    if ($user_ticket_md5 != $ticket_md5) {
        echo "Bad ticket";
        echo "$user_ticket_md5 should be equal to $ticket_md5"; // Add me
        exit();
then visit the RR link again (with the double hyphen reduced to just one, or course). I wanna see what the PHP thinks those backend MD5s are.
BanditBBS
Post by BanditBBS »
If I leave in the double - then I get the ticket should be "1"
If I knock it down to 1 - then I get this page:
abrist
Red Shirt
Post by abrist »
Hmmm, we may need to do a remote to really hunt this down . . . .
BanditBBS
Post by BanditBBS »
You know me, always willing....
abrist
Red Shirt
Post by abrist »
You available now?
