The first thing I can suggest is to upgrade the plugin to the latest version to see if this resolves the issue.
I went to find the URL for this and it seems that they've renamed the plugin to check_vmware_api.pl however it should run the same way as before.
Here is the download URL:
http://git.op5.org/gitweb?p=system-addo ... /maint/6.3
Let us know how this goes.
check_esx3 problem
- Box293
- Too Basu
Re: check_esx3 problem
