PDF Report Generation broken
GldRush98
Re: PDF Report Generation broken
Post by GldRush98 »
Yes, sorry. The full output is:
************ ERROR: Failed to render URL 'https://[redacted]/nagiosxi/reports/availability.php?1&hideoptions=1&username=noverstreet&ticket=[valid api key]&locale=en_US' as '/usr/local/nagiosxi/tmp/scheduledreport-noverstreet-1407791975-page.pdf' ************
I verified wkhtmltopdf is working properly by doing a "wkhtmltopdf http://www.google.com /tmp/google.pdf" and that did correctly generate a pdf file.
Here's that report.txt file from the curl command from above... dunno if that'll be helpful or not.
Prod XI: Debian 12 - Nagios XI 2026R1.2
Dev XI: Debian 12 - Nagios XI 2026R1.2
abrist
Red Shirt
Post by abrist »
Can we move this to a ticket? I think we will need to set up a remote to continue troubleshooting directly on the server. Please send an email from a registered address to: [email protected]
GldRush98
Post by GldRush98 »
I just wanted to update that I got this figured out today.
After doing the remote session yesterday, we determined that I was missing the openssl 32bit libs, and this was breaking wkhtmltopdf 32 bit from retrieving the https url.
I tried installing but ran in to a transaction error. Basically it was because my x64 openssl wasn't up to date.
So to fix it I had to:
yum update openssl
yum install openssl.i686
Now everything is working! 32 bit wkhtmltopdf is happy.
Post by slansing »
Excellent, thank you for letting us know.
