The version that was failing was 4.2 from labs.consol.de
I downloaded the present version 4.6.3.2.
I was though quite worried about modifying the set up that was running.
I had another nagios running for Continuity Test and so I ran my tests there.
This took me all day as I got other error messages I needed to clear.
I also had to delete and reset the snmp setting on the servers.
But now at last it now shows correct results.
Thank you for your input.
Do I close this post?
JulianD
check_hpasm incorrect results
Re: check_hpasm incorrect results
Can you also show a screenshot of a few of these services next to each other that are all showing the same info, and all for your local nagios server?
ok?
SYS - Hardware WARNING 20-08-2014 10:57:11 4d 10h 26m 29s 3/3 WARNING - controller accelerator battery recharging, System: 'proliant dl360p gen8', S/N: 'CZJ3430T1X', ROM: 'P71 02/10/2014'
Is a successful return on what we were looking for but this is for a linux server.
SYS - Hardware WARNING 20-08-2014 10:57:02 0d 19h 18m 50s 3/3 WARNING - controller accelerator battery needs attention, System: 'proliant dl360 g4', S/N: 'GBJ511015Z', ROM: 'P52 07/16/2007'
Now after I got this working for Windows Servers, and both of these are from our production nagios server.
thanks,
JulianD
ok?
thanks,
JulianD
