If you're not going to finish that Pi I'll take it.
Would it be possible for you to add a second network interface that goes to the VPN network? Or is that against policy?
Distributed Monitoring Advice/Questions
Re: Distributed Monitoring Advice/Questions
I'm fat, I have no leftovers! I'll be using it for somethingtmcdonald wrote:If you're not going to finish that Pi I'll take it.
And yes, that would end up being against policies. I think I'm good with either a NUC or just a custom built mini-itx solution. $200-$400 depending...still decent price and gives us more options with a true intel CPU and more ram.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
NUC's can be extremely powerful, we will be using a couple with quad core i5's to drive some touch screen displays at the conference this year... they are sweet.
Add in an SSD, and 16 GB of ram like these, and you are set.
