LOL, me too, that's why I posted in the first place! Its just very weird since some files are being removed but all perfdata seems to be getting processed.Box293 wrote:I've run out of ideas.
Perfdata folder filling, yet is processing
Re: Perfdata folder filling, yet is processing
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
- Box293
- Too Basu
PM the log files and I'll have a look at them.
I'll do that in a bit. The permissions on npcd.log weren't right and it wasn't being updated. I am going to remove all these old perf data files so we can say "from this time on"Box293 wrote:PM the log files and I'll have a look at them.
Did you PM Troy the log files? Are you still having an issue with perfdata folder filling up?
I'm about to PM them now. Yes I am still having the issue andseeing this in the log over and over:lmiltchev wrote:Did you PM Troy the log files? Are you still having an issue with perfdata folder filling up?
[09-03-2014 10:40:40] NPCD: File '1409694688.perfdata.service-PID-2783' is an already in process PNP file. Leaving it untouched.2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
Hmm, you may want to bump out your timeout value in:
If it is the default, I'd move it up to 30 seconds. In the past, I know a user had removed his RRD files and let them regenerate to fix the issue, I don't think it has any negative impact in most cases, but you may be missing some data points thus making your averages display at a lower resolution via the graphs. Of course, removing the RRD files is a bit rough, especially with a lot of valuable historical perf data.
EDIT: Whoa, didn't know it was at 120 already.
/usr/local/nagios/etc/pnp/process_perfdata.cfgEDIT: Whoa, didn't know it was at 120 already.
Timeout is already 120
- Box293
- Too Basu
I noticed the following warning in perfdata.log:
Try installing the module to see if it helps:
Timeout was my other suggestion however it appears that has been covered.
In nagios.cfg, what are the settings for:
RRDs Perl Modules are not installed. Falling back to rrdtool system call.Code: Select all
yum install rrdtool-perlIn nagios.cfg, what are the settings for:
service_perfdata_file_mode
service_perfdata_file_processing_command
host_perfdata_file_mode
host_perfdata_file_processing_commandAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
OMG - This day has just sucked!
Anyway, I can't get yum to function on this server, it gets to "Updating Red Hat repositories" and just freezes there for ever....bah
As for the other question:
Those commands are here:
service_perfdata_file_mode=a
service_perfdata_file_processing_command=process-service-perfdata-file-bulk
host_perfdata_file_mode=a
host_perfdata_file_processing_command=process-host-perfdata-file-bulkCode: Select all
command_name process-host-perfdata-file-bulk
command_line /bin/mv /var/nagiosramdisk/host-perfdata /var/nagiosramdisk/spool/xidpe/$TIMET$.perfdata.host
command_name process-service-perfdata-file-bulk
command_line /bin/mv /var/nagiosramdisk/service-perfdata /var/nagiosramdisk/spool/xidpe/$TIMET$.perfdata.service
}2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
These commands look fine. Can you run the following commands and show us the output?
ls /var/nagiosramdisk/spool/xidpe | wc -l
ls /var/nagiosramdisk/spool/perfdata/ | wc -l
ls /var/nagiosramdisk/spool/checkresults/ | wc -l
which rrdtool
rrdtool --version
