XI Config Import Prep Tool
Re: XI Config Import Prep Tool
Well, it usually is not, though it does require you to be meticulous here and there. Let us know how things go on the second run, after any outstanding config issues are resolved. I'd also make sure the configs themselves do not have config errors prior to uploading them, you should be able to verify them on the original system.
