Unauthorized login in nagios 4.0.8
Re: Unauthorized login in nagios 4.0.8
OK, I was able to install successfully nagios on ubuntu 10.04 64-bit by following our document. So I wonder if you got any errors while compiling. Were you able to install all of the prerequisites? Can you run the following command and show us the output?
dpkg-query -l wget build-essential apache2 php5-gd libgd2-xpm libgd2-xpm-dev libapache2-mod-php5
rafaelbraga
Post by rafaelbraga »
Hi!
I execute the command. See the result in the image below.
The package libgd2-xpm not found.
Obs: my system is updated.
pre-requisitos-nagios-2
I don't believe this package will cause the errors that you are getting... It's gd graphics library. Let's check some of the permissions - run the following commands and show us the output:
ls -lad /etc/apache2
ls -la /etc/apache2
ls -la /etc/apache2/conf.d
rafaelbraga
Hi!
Follows the result of the commands.
Sorry for the delay.
It seems like you are using zabbix... ("/etc/zabbix/apache.conf" from your screenshot) I would recommend trying again your nagios install on a clean system.
rafaelbraga
ok! I'll try.
Thanks for the trouble!
sreinhardt
-fno-stack-protector
Post by sreinhardt »
You're welcome! Going to lock this up for now, let us know if you still have issues later.
