[Email Notification] Host Down Check Attempt.
Re: [Email Notification] Host Down Check Attempt.
Post by Box293 »
igsadmin wrote:By the way, this is happen for all the host...
I just did a test... I changed retry interval from 1 min to 2 min in (xi_wizard_generic_host)
Noticed that, the retry interval now is 1 min after Host is DOWN.
When the intervals are defined on the host object, the template settings are overwritten. As you can see in your host definition the retry_interval is set to 1.
igsadmin wrote:Hi, this is the host definition,
# Host configuration file
# Created by: Nagios Core Config Manager 2.2.0
# Date: 2014-09-25 00:02:39
# Version: Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
define host {
host_name ABCD
use xiwizard_windowssnmp_host
address 10.10.68.3
hostgroups Jaya
max_check_attempts 5
check_interval 5
retry_interval 1
contacts igsadmin
notification_interval 0
_xiwizard windowssnmp
register 1
# END OF FILE
igsadmin
Post by igsadmin »
define host {
host_name ABCD
address 10.10.68.3
hostgroups Jaya
check_interval 5
retry_interval 1
contacts igsadmin
register 1
# END OF FILE
Yes.. The default setting for retry interval is set to 1 min.
This is happen when the Host is DOWN, the retry interval is 30 sec instead of 1 min.
When I changed the default retry interval from 1 min to 2 min.. When the Host is DOWN, the retry interval is 1 min instead of 2 min.
Kindly please advice is this a bug?
Can you email the "profile.zip" to [email protected]?
Admin->System Profile->Download Profile
igsadmin
Post by igsadmin »
lmiltchev wrote:Can you email the "profile.zip" to [email protected]?
Hi, I just email the profile.zip to [email protected]
The email Subject name is "[Email Notification] Host Down Check Attempt."
My email address is [email protected]
Thanks.
We got it. Thanks! We will continue communicating via emails. Locking this topic.
