NRPE
sreinhardt
- -fno-stack-protector
Re: NRPE
I'm not sure how it got there, since you are using xinetd, but I can't imagine it will cause too many issues provided you only have either xinetd or nrpe services running, personally go with xinetd.
spiderpig82
Re: NRPE
ok, do i have to define somewhere to use xinetd?
Re: NRPE
You likely won't need to change anything at this point, xinetd is smart enough to look at it's defined configurations and initialize what is contained within. If you issue:
It should re-initialize under xinetd.
service xinetd restart
