Did you update nagios.cfg to point to the new locations of your object files?navaho wrote:No Joy. I updated to 3.2.3 by removing the debs, hand building it from source, and dropping my configs in.
Unable to get $CONTACTEMAIL$ to expand
Re: Unable to get $CONTACTEMAIL$ to expand
Good morning!
Yes, I did. I'm pretty darn sure I have everything configured properly. Everything works, it just doesn't send email.
I set debug to -1 and found that it's telling me that the macro is failing. I'll grab a capture of that log in just a bit. Seems it rotated out over the night.
Someone suggested to try with on-demand macro $CONTACTEMAIL:navaho$ to see if it works which I will.
I turned on debugging with the original contact command
And this is what I got in the debug log. I've snipped it simply for brevity, I can paste the entirely of it if there is more that you would like to see.
I'm going to try running it again with $CONTACTEMAIL:navaho$ and see what that does.
/usr/bin/printf "%b" "Notification:\t$NOTIFICATIONTYPE$\n\nOccurred:\t$DATETIME$\nHostname:\t$HOSTALIAS$ ($HOSTADDRESS$)\nService:\t$SERVICEDESC$\nState:\t\t$SERVICESTATE$\nDetails:\n\n $OUTPUT$" | /usr/bin/mail -s "$NOTIFICATIONTYPE$: $HOSTALIAS$/$SERVICEDESC$ -- $SERVICESTATE$" "$CONTACTEMAIL$"
[1312391403.159137] [2048.2] [pid=4104] Not currently in macro. Running output (213): '/usr/bin/printf "%b" "Notification:\t\n\nOccurred:\t$DATETIME$\nHostname:\thostname (10.5.4.1)\nService:\tmy service\nState:\t\tCRITICAL\nDetails:\n\n $OUTPUT$" | /usr/bin/mail -s ": hostname/my service -- CRITICAL" "'
[1312391403.159152] [2048.2] [pid=4104] Processing part: 'CONTACTEMAIL'
[1312391403.159168] [2048.2] [pid=4104] macro_x[22] (CONTACTEMAIL) match.
[1312391403.159182] [2048.2] [pid=4104] Processed 'CONTACTEMAIL', Clean Options: 0, Free: 1
[1312391403.159196] [2048.0] [pid=4104] WARNING: An error occurred processing macro 'CONTACTEMAIL'!
I FOUND IT!
using the macro like this
Sent email to navaho@nagios server hostname not to the email address listed for navaho in contacts.cfg. That got me to thinking some more and i looked at the debug a little but more. That's where I saw the problem.
I changed $CONTACTEMAIL$ to "$CONTACTEMAIL$" and no go, but then I tried '$CONATACTEMAIL$' and it worked..
I still have to fix up $DATETIME$ as that's coming blank in the email as is $OUTPUT$ but that'll be easy. the hard part was making the email send at all.
Thanks for the sounding board!
/usr/bin/printf "%b" "Notification:\t$NOTIFICATIONTYPE$\n\nOccurred:\t$DATETIME$\nHostname:\t$HOSTALIAS$ ($HOSTADDRESS$)\nService:\t$SERVICEDESC$\nState:\t\t$SERVICESTATE$\nDetails:\n\n $OUTPUT$" | /usr/bin/mail -s "$NOTIFICATIONTYPE$: $HOSTALIAS$/$SERVICEDESC$ -- $SERVICESTATE$" '$CONTACTEMAIL:navaho$'
Glad to hear it was resolved, although the solution still doesn't make a whole lot of sense to me.
Same here. I'm looking over the original again, and I don't see any quotes that are escaped. That would do I think, but I don't see one.
What if one of the macros previous to $CONTACTEMAIL$ had unescaped HTML? (which for this service they do) Quotes in there would cause this, wouldn't they?
Just a followup, that was exactly what the issue was. In the mail command was
Details:\n\ n$OUTPUT$"
$OUTPUT$ has html in it. With /usr/bin/printf %b and a field that has html (including "'s) we were getting extra quotes and breaking the mail command.
We were ending up with this
/usr/bin/printf "%b" "Notification:\tPROBLEM: hostname/servicename -- CRITICAL\n\nOccurred:\tWed Aug 3 19:05:51 PDT 2011\nHostname:\tmy hostname (10.5.4.1)\nService:\tService description\nState:\t\tDOWN\nDetails:\n\n<a href="serviceurl.com">service url</a> | /usr/bin/mail -s "PROBLEM: myhostname/my service -- DOWN" [email protected]
It appears that quotes in the serviceurl link were breaking things. Using %s sort fo fixed the problem in that it fixed the quotes in $OUTPUT$ but of course broke the \t and \n that I was using, of course. I had to fix up my formatting, but I'm getting the email now. It's not optimal, but it works.
Good to know, thanks!
colintaylor
I had exactly this - and the problem was that I had my event handler(s) for hosts and services set to "notify_host_by_email" or "notify_service_by_email". The $CONTACTEMAIL$ macro is not available in the event handler parameters.
Hope that helps! (took me *weeks* to find that!)
