Command line check and GUI not matching
sreinhardt
-fno-stack-protector
Re: Command line check and GUI not matching
Post by sreinhardt »
Could you post the /etc/sudoers and /etc/sudoers.d/nagiosxi files? I have a feeling you are correct, that a duplicate entry is causing the issue. Let's have a look and see what needs to be changed!
notverynick
Post by notverynick »
Cheers, files attached, I have also attached the sudoers.old file I created at the start of this process.
(had to edit as I missed the extension warning. All files uploaded as .txt)
I believe you are getting this error as you commented out line 110. Change it, so that it would look like this:
User_Alias      NAGIOSXI=nagios
Save and exit. Did this fix your issue?
notverynick
Sadly that's where I started.
I can revert back to the original sudoers and I get the duplicate alias error, the alias is defined in /etc/sudoers.d/nagiosxi and then again in the /etc/sudoers I assume that as the /etc/sudoers.d/nagiosxi is imported via the include BEFORE the alias definition in /etc/sudoers that's why the /etc/sudoers errors.
The state I'm in now (as per the attached) gives me no errors and I am able to sudo correctly, BUT my check script (in which I am using sudo) is now requireing the nagios user to provide a password, even though I seemingly explicitly say NOPASSWD in the sudoers file?
abrist
Red Shirt
Post by abrist »
This is very odd - It must have something to do with check_hop. Maybe it is running another command that needs sudo. Can you open a ticket by emailing [email protected] ?
