Changed data location and now not working
Re: Changed data location and now not working
Could you also provide some insight regarding the first half of my last post? I'm waiting for my fresh VM to build up a few logs before I test.
Edit: Just did the following on the server:
service elasticsearch stop
mkdir /tmp/data
vi /etc/sysconfig/elasticsearch
    (changed line to:  DATA_DIR="/tmp/data")
mv /usr/local/nagioslogserver/elasticsearch/data/* /tmp/data
service elasticsearch start
and I am not seeing the same behavior. I am getting logs and can query, and the page shows logstash and elasticsearch working.
BanditBBS
Post by BanditBBS »
As stated, I undid the change. i think I hit some other issue, so removed the changes I made to try and resolve this one.
I am clearly still getting apache log information added to my file from the default source. When I go to the apache 404 query I see this on the top of one of the dashlets "Oops! FacetPhaseExecutionException[Facet [0]: (value) field [bytes] not found]"
Got a little busy here doing other things and will get back to you about your earlier requests asap.
EDIT: Seeing this over and over in the one dashboard:
2014-11-14T13:31:01.000-06:00	127.0.0.1	syslog	  nagios : command not allowed ; TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status
2014-11-14T13:31:01.000-06:00	127.0.0.1	syslog	  nagios : command not allowed ; TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/elasticsearch status
2014-11-14T13:30:46.000-06:00	127.0.0.1	syslog	  nagios : command not allowed ; TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/logstash status
2014-11-14T13:30:46.000-06:00	127.0.0.1	syslog	  nagios : command not allowed ; TTY=unknown ; PWD=/var/www/html/nagioslogserver/www ; USER=root ; COMMAND=/etc/init.d/elasticsearch status
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
BanditBBS
Post by BanditBBS »
Oh, CRAP!
We have an app that syncs ppk's and the sudoers file. I bet it ran and over wrote the sudoers file.
What does logserver add to the sudoers file on install so I can add it back in?
eloyd
Cool Title Here
Post by eloyd »
Nothing changed and suddenly it's not working.
User_Alias NAGIOSLOGSERVER=nagios
User_Alias NAGIOSLOGSERVERWEB=apache
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash start
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash stop
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash restart
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash reload
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash status
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch start
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch stop
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch restart
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch reload
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch status
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash start
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash stop
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash restart
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash reload
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash status
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch start
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch stop
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch restart
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch reload
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch status
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/usr/local/nagioslogserver/scripts/get_logstash_ports.sh
Here's the function from the install dir that handlers sudoers:
# Update sudoers file if it hasn't already been updated
sudoers() {
    # Remove old sudoers entries
    grep -v NAGIOSLOGSERVER /etc/sudoers > /etc/sudoers.new
    mv -f /etc/sudoers.new /etc/sudoers
    # Remove TTY requirement
    sed -i 's/Defaults    requiretty/#Defaults    requiretty/g' /etc/sudoers
    # Add new sudoers entries and set permissions
    cat nagioslogserver/nagioslogserver.sudoers >> /etc/sudoers
    chmod 440 /etc/sudoers
You might be able to run the upgrade script again, but not sure what all that would overwrite...
EDIT: eloyd, stop being so good at helping people :evil:
BanditBBS
Post by BanditBBS »
Thanks guys, expecially Eric since he was so much faster!
I am sure this is my entire issue and will get it added to the central server. You can close this up!
p.s. Eric - I never said nothing had changed! I started it out with "I just changed something and it doesn't work" LOL
eloyd
Cool Title Here
Post by eloyd »
Bandit,
I made up that quote. :-) But I hear it so often....
Trevor,
You're asking me to quit you?
cmerchant
Post by cmerchant »
We'll go ahead and close this one up.
eloyd wrote:You're asking me to quit you?
We both know that would end in tears and drowning our sorrows in chocolate cake. As much as I like cake, let's try and work out our differences. For Science.
