Check_HP plugin installation and use
szkoda
Re: Check_HP plugin installation and use
Post by szkoda »
do the permissions look correct?
Post by Box293 »
Lets go back to basics. Before we even start talking about Nagios configurations lets ensure the plugin runs from the command line.
On your Nagios box:
su nagios
/usr/local/nagios/libexec/check_hp -H IP_of_HP_server -C public
Where public is the SNMP community name on your HP server.
What output do you get?
szkoda
Post by szkoda »
All I get is:
"bash: /usr/local/nagios/libexec/check_hp: Permission Denied"
szkoda
Post by szkoda »
I tried with several different hosts just in case it was the SNMP permissions on the remote server but it made no difference.
I CAN use the built in "check_SNMP" function in Nagios which works ok with the remote windows server I'm trying to use "check_HP" with so I'm assuming I've configured SNMP correctly on the remote server.
Something is not adding up here.
When you say you can use the check_SNMP function, do you mean you can run the check_snmp plugin from the command line as the nagios user? Are the permissions the same on that plugin?
szkoda
Post by szkoda »
Yes and yes.
It's completely baffled me as well. Just to clarify how I installed the plugin:
1. downloaded the .tar archive from Nagios exchange on a windows PC.
2. transferred the archive over to the nagios server.
3. placed the check_hp file into the nagios plugins directory.
thats it. Is there any steps i've missed here?
P.S. I used a windows PC to download the archive because I didn't know how to with Linux.
Post by Box293 »
Can you try this command:
su nagios
/usr/local/nagios/libexec/check_hp -H IP_of_HP_server -C public -d
the -d is a debug mode which should show us some more information.
szkoda
Post by szkoda »
This is what I get once I've run the debug command:
"bash: /usr/local/nagios/libexec/check_hp: /usr/lib/nagios/plugins: bad interpreter: Permission denied"
so looks like its referencing the plugin in a different directory?
Can you attach a copy of the plugin here for us to review?
lgroschen
Post by lgroschen »
From the first page you were asked to make this change:
use lib "/usr/lib/nagios/plugins";
Change that to the following (which is default):
use lib "/usr/local/nagios/libexec";
Then run this on your command line:
ll -s /usr/local/nagios/libexec/utils.pm
this should be nagios:nagios for user:group
/Luke
