Nagios Log Server not sending alert Emails
Re: Nagios Log Server not sending alert Emails
networkeng wrote: Any idea on when the test mail server feature will be implemented?
Next release
networkeng wrote: Also, is there a good write up on how to integrate these Nagios Log Server alerts into Nagios-XI so we can just bypass this Log Server email issue altogether?
http://library.nagios.com/library/produ ... log-events
Just choose the NRDP alert method
You can get/set your NRDP token in XI from Admin -> Inbound Transfers
Also, there is a Log Server Wizard here
http://exchange.nagios.org/directory/Ad ... rd/details
Just save your queries and you can just run the wizard to set them up.
networkeng
Post by networkeng »
I upgraded to the latest version and now have the 'Test Settings' button. When I press it nothing happens or it turns to 'Please Wait'. My colleague (Exchange admin) tested it and let it run for several minutes. He received the error message attached below. It looks like Nagios Log Server does not like MS Exchange. The "error" message shows that the MAIL Service is ready. :?
cmerchant
Post by cmerchant »
What mail settings did you use in the logserver? (security, port and authentication), and do you know what the mail server requires?
lgroschen
Post by lgroschen »
Can you please let me know which version of MS Exchange you are using so I can try to replicate/test this.
That message is coming up because the Test button will try the send command and if it fails print out the message that was returned, also the MS Exchange server is using E(xtended)SMTP so I think the protocol will be passed differently than SMTP. Using current SMTP settings it is passing the protocol in front of the hostname for example SSL would look like ssl://localhost. The message you received is just saying that you successfully opened a command line terminal for the Mail service. So it didn't fail it just might need to have the mail arguments (host, protocol, etc.) passed all together and to send the mail instead of opening an interactive command line.
The return code 220 is explained from the microsoft website:
https://technet.microsoft.com/en-us/magazine/2005.11.howitworkssmtp.aspx wrote:The second and third digits provide further details, but at the top level, all that matters is that 1xx, 2xx, and 3xx are good, and 4xx and 5xx indicate problems. (For further information on mail response codes, read RFC 1893.)
/Luke
muratKURU
Post by muratKURU »
Hi All
Is this Problem now solved?
I can't send Email alert over Nagios Log Server either!
Very very frustrating! And I'm valuating this Tool hhmmm
@muratKURU -
What version are you running?
If it is 2014R1.3, what setting are you using in the mail settings?
Does the test mail setting succeed?
muratKURU
Post by muratKURU »
scottwilkerson wrote:@muratKURU -
@scottwilkerson
The version we are using is 2015R1.2.
We choose for the "Send Email Method" SMTP Server.
Test mail? Their is unfortunately no "send test mail" option.
I would definitely recommend upgrading to 1.3, not only is there a test email settings button, you can also verify that scheduled jobs (those that process alert emails) are running successfully.
muratKURU
Post by muratKURU »
Hi scottwilkerson
I did upgrade it to 1.3 but I still can't send Alert E-Mail.
Below the screenshot of the error message:
As you can see, I have the same error message as networkeng.
Please help.
Could you post your SMTP settings so we can review them?
