You need to identify the oid that you wish to check. It may be better to dump the walk's output to a file from the cli and then attach it to your next post so that we can look at the walk and help you identify the oid you are looking for:
V1:
This device has 7 external temperature sensors and 16 External Switch Sensors.
The external Switch's need to alert when the state is 'Closed' (they are currently all open----good)
the temperature settings should alert at 65.
Is there a chance that these values/oids are not pollable, and are only reported as events through snmp traps?
Specifically, if there is a web interface where you can configure the device I would look around for something like "Access List" or "Blocklist" or something similar where you can allow the Nagios IP to query.
Or these oids are only event-based traps. Can you contact the vendor for clarification?
