ndo2db error in /var/log/message
sagarjatti
Re: ndo2db error in /var/log/message
Only 1% of Inodes used if i look under IUse% column when i run the "df -i". command.
Run the following command again and post the output:
echo "repair table nagios.nagios_systemcommands use_frm;" | mysql -pnagiosxi Former Nagios employee
sagarjatti
Even thought i ran df -i command and i can see only 1% of Inodes are used remainign all are free only.
What was the output from my previous command?
sagarjatti
Hi abrist,
before also i tried to rurepair using this below command but it was no help, ut this time it worked and i don't see any such error in the /var/log/messages now.
Thanks for your help.
We'll go ahead and close the thread. Thanks.
