Here is the email setting.tgriep wrote:Go to Admin > System Config > Manage Email Settings and post back how the Mail Method is setup.
Hosts/Services problem notifition sender email is different
Re: Hosts/Services problem notifition sender email is differ
Try changing the Alert Settings, notification settings for the contacts with the wrong From address to the same notification settings as the contacts with the correct from address.
Sorry, I don't get what you mean.tgriep wrote:Try changing the Alert Settings, notification settings for the contacts with the wrong From address to the same notification settings as the contacts with the correct from address.
phyo,
I believe it is possible that you have some nagios contacts setup using using a notification handler other than
xi_host_notification_handler
xi_service_notification_handler
I would start with the users that are receiving messages from [email protected], go to the CCM -> Contact -> Alert Settings ->
Manage Host Notification Commands
Manage Service Notification Commands
Host notification commands is notify-host-by-emailI would start with the users that are receiving messages from [email protected], go to the CCM -> Contact -> Alert Settings ->
and Service notification commands is notify-service-by-email
All users has the same settings?
Do you did any changes on notify-service-by-email and notify-host-by-email?
Are you sure that all users has just "notify-service-by-email" or "notify-host-by-email" and not "xi_host_notification_handler" or "xi_service_notification_handler"?
Because on the screen shots that you provide it seems some of them has notify-host-by-email and some of them has xi_host_notification_handler.
In our system, we created two kind of contact.questrad wrote:All users has the same settings?
First one is created via Admin --> Users --> Manage Users and create new user. While create new user, I enable "Create as Monitoring Contact". For those contact, I used xi_host_notification_handler and xi_service_notification_handler.
Second one is created via Configure --> CCM --> Alerting --> Contacts and Add new contacts. For those contact, I used notify-host-by-email and notify-service-by-email.
All of the contact creating by first method got the correct email sender.
The contact creating by second method got the email from user@hostname email address.
It is because those setup with
and
Use different commands
You can edit these commands in the CCM -> Commands to change the sender email address. By default they will just use the systems email account and use /bin/mail to send the email..
When changing the commands for notify-host-by-email and notify-service-by-email you will want to likely add the following right after /bin/mail -r
and
/bin/mail -r "[email protected]" Re: Hosts/Services problem notifition sender email is differ
To avoid such of miss-configuration in our environment all notification types are included in contact template.
And when we creating contact we making sure that the contact has correct template and nothing else in Alert setting tab
So, we are sure that contact has correct notification settings.
OP, can you confirm if Scott's suggestion worked for you?scottwilkerson wrote:It is because those setup with
and
