This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
riconeo
Posts: 35 Joined: Mon Oct 14, 2013 8:32 am
Post
by riconeo » Tue Feb 10, 2015 10:20 am
scottwilkerson wrote: I looked at the plugin and I believe the problem was that the strings being echo'd were not in quotes. this may be fine for some strings, but once you add a pipe, bash is going to try to redirect output.
I edited the pligin and am posting below, however do not have the equipment to test it...
Hi Scott,
Thanks for the edit.
It seems to be getting some details now but the performance graph is still not showing.
The weird part is that, when I click on the graph icon, it does show the perfdata.
I have attached the screenshot of it.
Thanks.
riconeo
Post
by riconeo » Tue Feb 10, 2015 10:34 am
When I click on capacity planning, it is not showing correctly too.
Update:
Just an update on this.
The data is populated now.
I guess Nagios XI need more data in order to do a extrapolation (capacity planning) graph.
Will continue to monitor and feedback on this capacity graph.
Posts: 13589 Joined: Mon May 23, 2011 12:15 pm
Post
by lmiltchev » Tue Feb 10, 2015 11:01 am
Please, do. It is possible that there is a bug in the Capacity Planning, so any feedback that can help us with this would be appreciated! Thanks!
Be sure to check out our
Knowledgebase for helpful articles and solutions!
riconeo
Post
by riconeo » Tue Feb 10, 2015 8:35 pm
Another update on post the earlier post where there is no display on the performance graph.
Post:
http://support.nagios.com/forum/viewtop ... 21#p126315
It is showing after I checked the 'Use Highcharts for Perfdata Graphs:' checked box.
However, it would still be good if we know why it is not working due to that.
Thanks.
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Wed Feb 11, 2015 12:21 am
Can you please post a screenshot of the Advanced tab when viewing the service.
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
riconeo
Post
by riconeo » Thu Feb 12, 2015 1:29 am
Box293 wrote: Can you please post a screenshot of the Advanced tab when viewing the service.
Post
by Box293 » Thu Feb 12, 2015 1:32 am
You need to edit the script so it does not output that backslash \ between 59 and %
Privacy Policy .
riconeo
Post
by riconeo » Tue Feb 17, 2015 10:01 am
Thanks all.
This issue is resolved now.
I wonder how I can update the plugin stated in the library since the current copy is of older version and does not contain the perf data output.
