classifying Traps
hanya.radwan
Re: classifying Traps
Post by hanya.radwan »
sorry for delay , but this case after fixed , it appears again. although I manually reclassify the trap in snmptt.conf .
also there isn't find the mibs in these paths /etc/snmp/snmptt.ini.
and these paths not found
/usr/share/snmp/mibs/processed_mibs/smscagent.mib.txt
/usr/share/snmp/mibs/processed_mibs/smscagentb.mib.txt
how can I fix that.
ssax
Dreams In Code
Post by ssax »
Please attach your /etc/snmp/snmptt.conf and your /etc/snmp/snmptt.ini, it'll give us a better idea of any changes.
hanya.radwan
the files attached
ssax
Dreams In Code
Post by ssax »
Ok, here's an example:
Using your latest one, if I use grep on your snmptt conf files (all of them are listed at the bottom of /etc/snmp/snmptt.ini), this line will search through all your conf files:
grep -n 'smscSiwplmnWarningTrap' /etc/snmp/*.conf
You will see that you have duplicate entries in there, you should be able to remove the duplicates or change them all but make sure that they are the exact same ones (Name, OID, Match, etc).
hanya.radwan
I deleted all repeated traps, and when apply the below for each trap , the result just one .
[root@nms snmp]# grep -n 'smscSiwplmnWarningTrap' /etc/snmp/*.conf
/etc/snmp/snmptt.conf:10860:EVENT smscSiwplmnWarningTrap .1.3.6.1.4.1.3830.1.1.2.2.1.0.2024 "Status Events" Warning
also I modified snmptt.ini and delete any conf file related to these mibs , and restart snmptt, but the problem still.
also most of traps went to snmpttunknown.log, and stop appear on nagiosxi notificatiins after me changing the traps classifications manually.
ssax
Dreams In Code
Post by ssax »
I'm seeing this in the original snmptt.conf you posted:
EVENT smscInternalMajorTrap .1.3.6.1.4.1.3830.1.1.2.2.1.0.52 "Status Events" Normal
FORMAT Internal status information of the agent $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "Internal status information of the agent $*"
SDESC
NOTIFICATIONID-VARIABLE: trapNotificationId
SEVERITY-VARIABLE: trapSeverity
ADDITIONAL-TEXT-VARIABLES: {trapData}
MANAGEDOBJECT-DEFAULT: smscAgent
Variables:
  1: trapNotificationId
  2: trapSeverity
  3: trapData
  4: trapTimeStamp
EDESC
And I'm seeing this in the new one:
EVENT smscInternalMajorTrap .1.3.6.1.4.1.3830.1.1.2.2.1.0.52 "Status Events" Critical
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$1" "Internal status information of the agent $*"
MATCH $1: 1
MATCH $1: 2
MATCH $1: 5
I think you removed too much.
Post by Box293 »
Looking at the first couple of in your unknown log, they are all similar, here is one:
Sun Apr 19 03:28:27 2015: Unknown trap (.1.3.6.1.4.1.3830.1.1.2.2.1.0.52) received from 192.168.10.71 at:
Value 0: 192.168.10.71
Value 1: 192.168.10.71
Value 2: 24:9:21:28.95
Value 3: .1.3.6.1.4.1.3830.1.1.2.2.1.0.52
Value 4: 192.168.10.204
Value 5: Jawwal-snmp
Value 6: .1.3.6.1.4.1.3830.1.1.2.2.1
Value 7:
Value 8:
Value 9:
Value 10:
Ent Value 0: .1.3.6.1.4.1.3830.1.1.2.1.1.1=3
Ent Value 1: .1.3.6.1.4.1.3830.1.1.2.1.1.2=2
Ent Value 2: .1.3.6.1.4.1.3830.1.1.2.1.1.3=%SMSA-E-POLLERR, Polling the SMSC was not successful.
Ent Value 3: .1.3.6.1.4.1.3830.1.1.2.1.1.4=OPCOM
Ent Value 4: .1.3.6.1.4.1.3830.1.1.2.1.1.5=19-APR-2015 03:27:10.70
Ent Value 5: .1.3.6.1.4.1.3830.1.1.2.1.1.6=SMJL51
Now to refer to this:
MATCH $1: 1
MATCH $1: 2
MATCH $1: 5
So $1 that is trying to be matched against is this:
$1 = Ent Value 0
So your MATCH is not matching anything as the value of Ent Value 0 ($1) is 3 and your MATCHES are:
MATCH $1: 1
MATCH $1: 2
MATCH $1: 5
You could add 3 as well:
MATCH $1: 1
MATCH $1: 2
MATCH $1: 3
MATCH $1: 5
Does that make sense?
