Error while fetching http
Re: Error while fetching http
I have run the command with verbose arguement at nagios monitoring server, Kindly check the attachment files.
httpd hostname.txt- (2.4 KiB) Downloaded 276 times
httpd ipaddr.txt- (2.32 KiB) Downloaded 273 times
- Box293
- Too Basu
I can see some errors in the output.
Does this solution work for you?
http://support.hostgator.com/articles/s ... s-disabled
#rpm -ql magento
package magento is not installed.
- Box293
- Too Basu
It's strange as the output contains:
I know this is an obvious question, but is 167.114.10.157 the correct IP Address?
<a href="http://elan.pk/" title="Magento Commerce" class="logo"><img src="images/logo.gif" alt="Magento Commerce" /></a>As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Got it, yes it's working
Thanks alot. You're great
