Hi tgriep,
Here below the content of my freetds.conf
# server specific section
[global]
# TDS protocol version
; tds version = 8.0
# Whether to write a TDSDUMP file for diagnostic purposes
# (setting this to /tmp is insecure on a multi-user system)
; dump file = /tmp/freetds.log
; debug flags = 0xffff
# Command and connection timeouts
; timeout = 10
; connect timeout = 10
# If you get out-of-memory errors, it may mean that your client
# is trying to allocate a huge buffer for a TEXT field.
# Try setting 'text size' to a more reasonable limit
text size = 64512
# A typical Sybase server
[egServer50]
host = symachine.domain.com
port = 5000
tds version = 5.0
# A typical Microsoft server
[egServer70]
host = ntmachine.domain.com
port = 1433
tds version = 7.0
[sqlhost1]
server = <first server that i successfully run the check>
port = 1433
tds version = 8.0
[sqlhost2]
server = <second server that i want to add>
port = 30127
tds version = 8.0
[sqlhost3]
server = <third server that i want to add>
port = 30127
tds version = 8.0
below is the sample commands
command_name check_sqlhealth_Server2_free-list-stalls
command_line $USER1$/check_mssql_health --server xx.xx.xx.xx --username username --password password --port 30127 --name server2 --mode free-list-stalls
check mssql health
Re: check mssql health
For the second server, try changing the check command to the following.
Change it from
to
Run it and post back any errors that you receive.
Change it from
command_line $USER1$/check_mssql_health --server xx.xx.xx.xx --username username --password password --port 30127 --name server2 --mode free-list-stallsCode: Select all
command_line $USER1$/check_mssql_health --server xx.xx.xx.xx --username username --password password --port 30127 --name sqlhost2 --mode free-list-stallsBe sure to check out our Knowledgebase for helpful articles and solutions!
Hi tgriep,
I did change my commands as per your advise. Please my error below.
CRITICAL - cannot connect to <server IP>. DBI connect(':server=<server IP>','<server username>',...) failed: OpenClient message: LAYER = (0) ORIGIN = (0) SEVERITY = (78) NUMBER = (41)
Server <server IP>, database
Message String: Unable to connect: Adaptive Server is unavailable or does not exist
at /usr/local/nagios/libexec/check_mssql_health line 1981
Hi Everyone,
I've successfully add my two additional server to be check, i just change my freetds.conf as seen below, since my first server is working in that configuration i didn't change it.
[sqlhost1]
server = <first server IP>
port = 1433
tds version = 8.0
[<second server IP>]
host = <second server IP>
port = 30127
tds version = 8.0
[<third server IP>]
host = <third server IP>
port = 30127
tds version = 8.0
and here is my commands
command_line $USER1$/check_mssql_health --server <server IP> --username username --password password --port 30127 --name <server name> --mode free-list-stalls
Thank you all for the response it help me a lot
[sqlhost1]
port = 1433
tds version = 8.0
port = 30127
tds version = 8.0
[<third server IP>]
port = 30127
tds version = 8.0
