This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Thu Feb 12, 2015 12:15 am
Thanks for that.
So now what output do you get when you run this at the command line of your Nagios XI host:
/usr/local/nagios/libexec/check_nrpe -H 192.168.168.12 -c check_disk -a '-w 20% -c 10% -p /'
Also, on your remote host, ssh to it and run these commands and show us the output:
su nagios
/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
timlee
Posts: 60 Joined: Mon Jan 12, 2015 10:01 pm
Post
by timlee » Thu Feb 12, 2015 1:28 am
Box293 wrote: Thanks for that.
su nagios
Thanks for following up.
From Nagios XI:
[root@NagiosCentOS6 ~]# /usr/local/nagios/libexec/check_nrpe -H 192.168.168.123 -c check_disk -a '-w 20% -c 10% -p /'
CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
From remote host:
[root@localhost ~]# /usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /
DISK OK - free space: / 4754 MB (67% inode=84%);| /=2330MB;5976;6723;0;7470
Remote host log:
[root@localhost ~]# tail /var/log/messages
Feb 12 01:25:48 localhost nrpe[10999]: Client request was invalid, bailing out...
Feb 12 01:25:48 localhost xinetd[25224]: EXIT: nrpe status=0 pid=10999 duration=0(sec)
Feb 12 01:26:10 localhost xinetd[25224]: START: nrpe pid=11128 from=::ffff:192.168.168.124
Feb 12 01:26:10 localhost nrpe[11128]: Error: Request contained command arguments, but argument option is not enabled!
Feb 12 01:26:10 localhost nrpe[11128]: Client request was invalid, bailing out...
Feb 12 01:26:10 localhost xinetd[25224]: EXIT: nrpe status=0 pid=11128 duration=0(sec)
Feb 12 01:26:11 localhost xinetd[25224]: START: nrpe pid=11129 from=::ffff:192.168.168.127
Feb 12 01:26:11 localhost nrpe[11129]: Error: Request contained command arguments, but argument option is not enabled!
Feb 12 01:26:11 localhost nrpe[11129]: Client request was invalid, bailing out...
Feb 12 01:26:11 localhost xinetd[25224]: EXIT: nrpe status=0 pid=11129 duration=0(sec)
Post
by Box293 » Thu Feb 12, 2015 1:37 am
On the remote host, I'm pretty sure these steps haven't been done:
Edit /usr/local/nagios/etc/nrpe.cfg
Change:
To:
Also, your remote host test shows the test being executed as root, please make sure you do the test like this:
su nagios
Privacy Policy .
timlee
Post
by timlee » Thu Feb 12, 2015 9:44 pm
Box293 wrote: On the remote host, I'm pretty sure these steps haven't been done:
Change:
To:
su nagios
running the check_disk command as nagios user works. I have verified that the remote host dont_blame is set to 1.
Now i'm getting another type of error on most of the services (except load,ping,users) - e.g.
(NRPE: Command 'check_disk' not defined)
Please help.
Post
by Box293 » Thu Feb 12, 2015 10:03 pm
On the remote machine, in the file:
Can you confirm if this exists:
include_dir=/usr/local/nagios/etc/nrpe
If it does, does check_disk exist inside of /usr/local/nagios/etc/nrpe/common.cfg ?
Privacy Policy .
timlee
Post
by timlee » Thu Feb 12, 2015 10:27 pm
Box293 wrote: On the remote machine, in the file:
Hi, it shows this:
# INCLUDE CONFIG FILE
# This directive allows you to include definitions from an external config file.
#include=<somefile.cfg>
# INCLUDE CONFIG DIRECTORY
# This directive allows you to include definitions from config files (with a
# .cfg extension) in one or more directories (with recursion).
#include_dir=<somedirectory>
#include_dir=<someotherdirectory>
I changed the directory to this:
#include_dir=/usr/local/nagios/etc/nrpe
Under /usr/local/nagios/etc/nrpe/common.cfg, I suppose it exist.
### DISK ###
command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$
command[check_ide_smart]=/usr/local/nagios/libexec/check_ide_smart $ARG1$
Post
by Box293 » Thu Feb 12, 2015 10:29 pm
Almost there.
Change This:
To This:
Privacy Policy .
timlee
Post
by timlee » Thu Feb 12, 2015 10:40 pm
Box293 wrote: Almost there.
Change This:
To This:
Thanks heaps! It works! I think we are almost done, just a couple of checks left...
1) Sendmail with error *** sendmail: Nok ***
2) System Logging Daemon NRPE: Unable to read output
3) Yum Updates YUM WARNING: O/S requires an update (Which I think i can ignore at this point of time)
Please advise.
Post
by Box293 » Thu Feb 12, 2015 10:47 pm
timlee wrote: Thanks heaps! It works! I think we are almost done, just a couple of checks left...
Excellent!
timlee wrote: 1) Sendmail with error *** sendmail: Nok ***
1 & 2
Configure - > Core Configuration Mananger
Monitoring -> Services
Find one of the services that is not currently working
Click the Disk icon for it
Paste the contents of the output from the disk icon here in a code block.
3
Do a yum update on the remote host to install the updates.
Privacy Policy .
timlee
Post
by timlee » Thu Feb 12, 2015 10:57 pm
1 & 2
3
For Sendmail:
host_name 192.168.168.123
service_description Sendmail
use xiwizard_nrpe_service
check_command check_nrpe!check_services!-a 'sendmail'
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 60
contacts nagiosadmin
_xiwizard linux-server
register 1
For Syslog:
service_description System Logging Daemon
check_command check_nrpe!check_init_service!-a 'syslog'
check_interval 5
retry_interval 1
register 1
