This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
JohnFLi
Posts: 559 Joined: Mon Jun 17, 2013 3:11 pm
Post
by JohnFLi » Thu Feb 12, 2015 7:00 pm
well...
Got them to change the password, and replaced the ( with a -
I removed all the items out of XI, and re-ran the wizard.
For the port status, I am getting.
Usage /usr/local/nagios/libexec/check_ifoperstatnag:
Check_ifoperstatus requires that the first argument be the interface index that this interface can be found at under the remote devices snmp tree.
This should always be a positive integer, or zero.
All options beyond the first, are arguments that must follow the snmpget command line parameters.
The settings are the same as before, just a different password now.
would any of these characters be the issue:
Everybody is somebody else’s weirdo
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Thu Feb 12, 2015 7:55 pm
What happens if you try from the CLI?
I have a feeling the length needs to be 8, yours is 7.
Length: 7
./check_ifoperstatnag 16797696 -v3 -u sanswitchmonitor.svc -A k%pLZ-J -a MD5 -l authNoPriv 10.25.5.15
No log handling enabled - turning on stderr logging
Error: passphrase chosen is below the length requirements of the USM (min=8).
snmpwalk: (The supplied password length is too short.)
Error generating a key (Ku) from the supplied authentication pass phrase.
snmpget: (The supplied password length is too short.)
UNKNOWN - No info is being retrieved.
Length: 8
./check_ifoperstatnag 16797696 -v3 -u sanswitchmonitor.svc -A k%pLZ-Ja -a MD5 -l authNoPriv 10.25.5.15
snmpwalk: Timeout (Sub-id not found: (top) -> ifOperStatus)
snmpget: Timeout (Sub-id not found: (top) -> ifDescr)
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
JohnFLi
Post
by JohnFLi » Fri Feb 13, 2015 11:05 am
I dont understand what you mean a length of 8??
From the cli
./check_ifoperstatnag 16801792 -v3 -u sanswitchmonitor.svc -A k%pLk304UZ-J -a MD5 -l authNoPriv -H dc-n5k-s2
Usage ./check_ifoperstatnag: <interface index> <snmpget options>
[root@G1VPNAG03 libexec]#
JohnFLi
Post
by JohnFLi » Fri Feb 13, 2015 1:34 pm
The passphrase is 12 in length.
I was just shortening the password for posting
Posts: 19396 Joined: Tue Nov 15, 2011 3:11 pm
Post
by scottwilkerson » Fri Feb 13, 2015 2:54 pm
2 more things, canyou attempt quoting the password and run from the CLI
./check_ifoperstatnag 16801792 -v3 -u sanswitchmonitor.svc -A "k%pLk304UZ-J" -a MD5 -l authNoPriv -H dc-n5k-s2
Also, can you verify what version of the Switch/Router Wizard you are running from Admin -> Manage Config Wizards
Posts: 9190 Joined: Thu Oct 30, 2014 9:02 am
Post
by tgriep » Fri Feb 13, 2015 2:56 pm
Could you run the following command and post back the walk.txt file?
snmpwalk dc-n5k-s2 -v3 -u sanswitchmonitor.svc -A k%pLk304UZ-J -a MD5 -l authNoPriv >walk.txt
Which interface are you trying to monitor?
Be sure to check out our
Knowledgebase for helpful articles and solutions!
JohnFLi
Post
by JohnFLi » Fri Feb 13, 2015 4:10 pm
Scott------- Network Switch/Router version 2.15
[root@G1VPNAG03 libexec]# ./check_ifoperstatnag 16801792 -v3 -u sanswitchmonitor.svc -A "k%pLk304UZ-J" -a MD5 -l authNoPriv -H dc-n5k-s2
TGRIEP ---------
see attached file
JohnFLi
Post
by JohnFLi » Fri Feb 13, 2015 4:38 pm
I just ran across
http://support.nagios.com/forum/viewtop ... 16&t=30816
when it said to open the check_ifoperstatusnag file
and change
if test -z "$1" || ! [[ "$1" =~ '^[0-9]+$' ]]; then
to
if test -z "$1" || ! [[ "$1" =~ ^[0-9]+$ ]]; then
now I get
Configuration directives understood:
In snmp.conf and snmp.local.conf:
alias NAME TRANSPORT_DEFINITION
doDebugging (1|0)
debugTokens token[,token...]
logTimestamp (1|yes|true|0|no|false)
mibdirs [mib-dirs|+mib-dirs|-mib-dirs]
mibs [mib-tokens|+mib-tokens]
mibfile mibfile-to-read
showMibErrors (1|yes|true|0|no|false)
commentToEOL (1|yes|true|0|no|false)
strictCommentTerm (1|yes|true|0|no|false)
mibAllowUnderline (1|yes|true|0|no|false)
mibWarningLevel integerValue
mibReplaceWithLatest (1|yes|true|0|no|false)
printNumericEnums (1|yes|true|0|no|false)
printNumericOids (1|yes|true|0|no|false)
escapeQuotes (1|yes|true|0|no|false)
dontBreakdownOids (1|yes|true|0|no|false)
quickPrinting (1|yes|true|0|no|false)
numericTimeticks (1|yes|true|0|no|false)
oidOutputFormat integerValue
suffixPrinting integerValue
extendedIndex (1|yes|true|0|no|false)
printHexText (1|yes|true|0|no|false)
printValueOnly (1|yes|true|0|no|false)
dontPrintUnits (1|yes|true|0|no|false)
hexOutputLength integerValue
dumpPacket (1|yes|true|0|no|false)
reverseEncodeBER (1|yes|true|0|no|false)
defaultPort integerValue
defCommunity string
noTokenWarnings (1|yes|true|0|no|false)
noRangeCheck (1|yes|true|0|no|false)
persistentDir string
tempFilePattern string
noDisplayHint (1|yes|true|0|no|false)
16bitIDs (1|yes|true|0|no|false)
clientaddr string
clientaddrUsesPort (1|yes|true|0|no|false)
serverSendBuf integerValue
serverRecvBuf integerValue
clientSendBuf integerValue
clientRecvBuf integerValue
noPersistentLoad (1|yes|true|0|no|false)
noPersistentSave (1|yes|true|0|no|false)
noContextEngineIDDiscovery (1|yes|true|0|no|false)
defDomain application domain
defTarget application domain target
defSecurityModel string
defSecurityName string
defContext string
defPassphrase string
defAuthPassphrase string
defPrivPassphrase string
defAuthMasterKey string
defPrivMasterKey string
defAuthLocalizedKey string
defPrivLocalizedKey string
defVersion 1|2c|3
defAuthType MD5|SHA
defPrivType DES|AES
defSecurityLevel noAuthNoPriv|authNoPriv|authPriv
In snmpapp.conf and snmpapp.local.conf:
engineID string
engineIDType num
engineIDNic string
doDebugging (1|0)
defCommunity string
clientaddr string
defContext string
defVersion 1|2c|3
defAuthType MD5|SHA
defPrivType DES|AES
engineID string
engineIDType num
engineIDNic string
./check_ifoperstatnag: line 40: [: -eq: unary operator expected
doDebugging (1|0)
defCommunity string
clientaddr string
defContext string
defVersion 1|2c|3
defAuthType MD5|SHA
defPrivType DES|AES
engineID string
engineIDType num
engineIDNic string
JohnFLi
Post
by JohnFLi » Fri Feb 13, 2015 5:03 pm
So now that I am not getting an error....
For Bandwidth on the ports, it all shows ZEROS
