braindope
Posts: 80 Joined: Fri Sep 26, 2014 12:13 am
Post
by braindope » Mon Mar 02, 2015 7:19 pm
Hi jdalrymple,
below is the output, can you direct me to the easiest and simplest way to resolved my issue, thanks
[root@pwnagios ~]# ll /usr/bin/java
lrwxrwxrwx 1 root root 22 Feb 18 14:48 /usr/bin/java -> /etc/alternatives/java
As far as i know the server only host our nagios
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Mon Mar 02, 2015 7:50 pm
Lets change the group to the nagios group:
Does that fix your problem?
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
braindope
Post
by braindope » Wed Mar 04, 2015 6:37 pm
Hi Box,
Sorry for the late reply, still the output is
unknown
Post
by Box293 » Thu Mar 05, 2015 12:47 am
Try setting the debug level on and then restart Nagios.
sed -i 's/.*debug_level=.*/debug_level=-1/g' /usr/local/nagios/etc/nagios.cfg
service nagios restart
Then go and schedule an immediate check of the service
This will be logged in the file /usr/local/nagios/var/nagios.debug
You will see how the command is constructed and what is being executed.
Does this help identify anything?
When you are finished this turns debugging off:
sed -i 's/.*debug_level=.*/debug_level=0/g' /usr/local/nagios/etc/nagios.cfg
Privacy Policy .
braindope
Post
by braindope » Tue Mar 10, 2015 4:35 am
I can't still see any hint on my error.. after debugging
, any other idea?
Update:
I have successfully fixed my error, what i did is i just add
command_name check_sqllog
command_line $USER1$/check_sqllog -H $HOSTADDRESS$ -u $ARG1$ -p $ARG2$
to my commands.cfg
and it magically work
Posts: 9117 Joined: Mon Sep 23, 2013 8:40 am
Post
by tmcdonald » Tue Mar 10, 2015 10:31 am
Good to hear!
I'll be closing this thread now, but feel free to open another if you need anything in the future!
