Nagios XI Caching Alert Data
abrist
Red Shirt
Re: Nagios XI Caching Alert Data
Post by abrist »
If you delete all the hots/service configs and then force a write , verify and apply config, do you still have the issue?
1. Go to CCM --> Write Config Files.
2. Click "Delete" and then "Write" and then "Verify".
3. If the config verifies ok, go ahead and apply config. If it does not, post the errors from verify here.
jstoddart
Post by jstoddart »
Ok, did that and verify was ok
Checking objects...
Warning: Service 'Failed Emails' on host 'STW Db - Query' has no default contacts or contactgroups defined!
Checked 734 services.
Warning: Host 'STW Db - Query' has no default contacts or contactgroups defined!
Checked 83 hosts.
Checked 14 host groups.
Checked 0 service groups.
Warning: Host recovery notification option for contact 'nagiosadmin' doesn't make any sense - specify down and/or unreachable options as well
Warning: Service recovery notification option for contact 'nagiosadmin' doesn't make any sense - specify critical and/or warning options as well
Checked 21 contacts.
Checked 4 contact groups.
Checked 127 commands.
Checked 25 time periods.
Checked 0 host escalations.
Checked 83 hosts
Checked 0 host dependencies
Checked 25 timeperiods
Checking misc settings...
Total Warnings: 4
Total Errors: 0
Still have the same issue and the Barnsley host is still appearing
It's possible that you have multiple instances of nagios or ndo running. Try stopping/starting services:
service nagios stop
killall nagios
service ndo2db stop
killall ndo2db
service ndo2db start
service nagios start
Let us know if this solved your issue.
jstoddart
Post by jstoddart »
That looks to have resolved it :D Thankyou
How does the server get in that state and what would you recommend as the best solution for it?
I suppose nagios didn't restart properly for some reason. Anyway, I am glad the issue was resolved. I am locking this topic. If you have any more issues/questions, please start a new thread. Thanks!
