existing object shows as unconfigured object in wizard
nagiosadmin42
Re: existing object shows as unconfigured object in wizard
Yes, those checks are for the correct placeholder type host. There are over 300 of them, so list did get cut-off in the screenshot.
-Jason
-Jason
- Box293
- Too Basu
OK I understand what your issue is.
When this problem occurs, do the services appear when viewing in the Nagos Core interface?
Open a webpage to http://nagiosserverip/nagios
NOTE the URL points to /nagios
Provide nagiosadmin username and password
In the left pane, under Quick Search, search for proxy-server
Do the services appear?
I'm just trying to make sure that the back end (core) is correctly functioning. This may just be an XI visualisation issue.
nagiosadmin42
Thanks for the quick replies.
I get one item, which is for the host 'proxy-server', but no services for that host show up.
I've attached a screen shot.
- Box293
- Too Basu
OK this actually points us in the direction of Nagios Core being the issue.nagiosadmin42 wrote:Thanks for the quick replies.
As pointed out, XI sees unconfigured objects by looking at the file /usr/local/nagios/nagiosxi/var/corelog.newobjectsmp4783 wrote:The tech support guys can weigh in on this, but I think that if you empty the /usr/local/nagios/nagiosxi/var/corelog.newobjects file, the checks should disappear from the unconfigured objects display. I could be wrong, so make a copy if you try this.
This file gets populated by a backend process. This process watches /usr/local/nagios/var/nagios.log for any entries like this:
[1416634449] Warning: Passive check result was received for service 'xxx Service Name xxx' on host 'yyy Host Name yyy', but the service could not be found!The best way to diagnose this moving forward is to turn on debugging:
Try setting the debug level on and then restart Nagios.
sed -i 's/.*debug_level=.*/debug_level=-1/g' /usr/local/nagios/etc/nagios.cfg
service nagios restartSo when the problem next occurs, we can look in nagios.debug for the entries I described above. We can then look backwards at the debug log to see what is happening before hand and hopefully identify what is causing this.
When you are finished this turns debugging off:
sed -i 's/.*debug_level=.*/debug_level=0/g' /usr/local/nagios/etc/nagios.cfg
service nagios restartAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
nagiosadmin42
I'll give that a shot.
I'm limited on / so I'll run this tomorrow.
Thanks.
Thanks.
Let us know how it went.I'll give that a shot.
nagiosadmin42
I cleared the Unconfigured objects, configured Nagios to log debug, and restarted a few hours ago.
The debug log is being populated now. As soon as I get a hit on Unconfigured Objects, I'll update this post.
-Jason
-Jason
No problem - we are all ears
nagiosadmin42
Ok. Couple of things.
1. Got the Unconfigured Obj. notification at 1:08 PM PST.
2. Turned debug on at about 11:45 am
3. Debug log time stamp is in epoc (PITA), but converts to 1:34 PM PST.
4. There are two Nagios debug logs, nagios.debug and nagios.debug.old. Both with A times of 1:34. I figured the first one rolled over, no issue there, however
looking at both log files there are no entries for 'PROXY-SERVER'.
I thought I'd take a look at the nagios.log file and found a bunch these (SANITIZED == removed customer name):
[1425970801] Error: Got check result for service 'Timed out txn count for All Apps - Web2.0 SANITIZED' on host 'PROXY-SERVER'. Unable to find service
[1425970801] Error: Got check result for service 'User count for All Apps - Web2.0 SANITIZED' on host 'PROXY-SERVER'. Unable to find service
[1425970801] Error: Got check result for service 'User count for SANITIZED - Web2.0 SANITIZED' on host 'PROXY-SERVER'. Unable to find service
[1425970801] Error: Got check result for service 'Transaction count for SANITIZED - Web2.0 SANITIZED' on host 'PROXY-SERVER'. Unable to find service
[1425970801] Error: Got check result for service 'Transaction count for All Apps - Web2.0 SANITIZED' on host 'PROXY-SERVER'. Unable to find service
[1425970801] Error: Got check result for service 'Transaction count for Error 2004 - Web2.0 SANITIZED' on host 'PROXY-SERVER'. Unable to find service
I'm not sure why 'PROXY-SERVER' is not in the debug log, and shouldn't the debug log time stamp be when I restarted Nagios to enable debug?
-Jason
-Jason
- Box293
- Too Basu
So far we have determined that Nagios is not seeing these services that already exist.
With the debug log, please confirm that -1 is the level (thats negative 1).
Then:
Starting with a fresh debug log will remove any confusion
I would like to see the debug log in full, please PM me the log.
How are these check results being received? SNMP? NRDP? NSCA?
Then:
service nagios stop
rm -f /usr/local/nagios/var/nagios.debu*
service nagios startI would like to see the debug log in full, please PM me the log.
