Passive checks with NCPA and NRDP
monitor86
Re: Passive checks with NCPA and NRDP
Post by monitor86 »
Ah, of course that should be changed but unfortunately I still get the same timeout issue. :cry:
Yes, I'm available to connect to the https://server/nrdp address. Tried sending the check manually and I get an OK back but the nagios.log still says timeout.
Can you remove these 2 settings from the service check and see if the timeout is fixed?
parallelize_check 1
obsess 1
When you did this
Can you show us how you did this?
