abrist wrote:sudha19rsan wrote: normal_check_interval 5
retry_check_interval 1
Are you using Manubulon and not Nagios? These directives are not nagios directives, as the nagios directives would be:
check_interval 5 retry_interval 1
Service orphaned Issue
jdalrymple
- Skynet Drone
Re: Service orphaned Issue
It seems like you didn't answer this:
sudha19rsan
Actually in template definition we have defined only check_interval and retry_interval. But in the service object definition only I had specified like normal_check_interval and retry interval... I have comment over it and restarted the services still the same issue persist..
jdalrymple
- Skynet Drone
If you look at the service configuration in the Nagios core interface, is it as you would expect?
