NRDP Config Problem
Re: NRDP Config Problem
Can you delete those check files out of /tmp and see if they get recreated after you submit a check result.
One test you might do after you've deleted them out of temp is to stop the nagios service and then submit the check through the NRDP interface and see if they show up in /tmp, /usr/local/nagios/var/tmp, or in /usr/local/nagios/var/spool/checkresults.
Still fighting the /tmp problem. Further detail
grep -r check_results_dir /usr/local/nrdp
grep -r tmp /usr/local/nrdp
/usr/local/nrdp/server/index.php: if(!isset($cfg["check_results_dir"]))
/usr/local/nrdp/server/index.php: if(!file_exists($cfg["check_results_dir"]))
/usr/local/nrdp/server/index.php: $tmpname=tempnam($cfg["check_results_dir"],"c");
/usr/local/nrdp/server/config.inc.php:$cfg["check_results_dir"]="/usr/local/nagios/var/spool/checkresults";
/usr/local/nrdp/server/plugins/nagioscorepassivecheck/nagioscorepassivecheck.inc.php: if(!isset($cfg["check_results_dir"]))
/usr/local/nrdp/server/plugins/nagioscorepassivecheck/nagioscorepassivecheck.inc.php: if(!file_exists($cfg["check_results_dir"]))
/usr/local/nrdp/server/plugins/nagioscorepassivecheck/nagioscorepassivecheck.inc.php: $tmpname=tempnam($cfg["check_results_dir"],"c");
/usr/local/nrdp/server/index.php: $fh=fopen($tmpname,"w");
/usr/local/nrdp/server/index.php: chgrp($tmpname,$cfg["nagios_command_group"]);
/usr/local/nrdp/server/index.php: chmod($tmpname,0770);
/usr/local/nrdp/server/index.php: $fh=fopen($tmpname.".ok","w+");
/usr/local/nrdp/server/config.inc.php:// NOTE: the Apache user need to be able create files here, and the Nagios user needs to read/delete those same files, so the /tmp system directory won't work (it has a sticky bit on it)
/usr/local/nrdp/server/config.inc.php:$cfg["tmp_dir"]="/usr/local/nagios/var/tmp";
/usr/local/nrdp/server/plugins/nagioscorepassivecheck/nagioscorepassivecheck.inc.php: $fh=fopen($tmpname,"w");
/usr/local/nrdp/server/plugins/nagioscorepassivecheck/nagioscorepassivecheck.inc.php: chgrp($tmpname,$cfg["nagios_command_group"]);
/usr/local/nrdp/server/plugins/nagioscorepassivecheck/nagioscorepassivecheck.inc.php: chmod($tmpname,0770);
/usr/local/nrdp/server/plugins/nagioscorepassivecheck/nagioscorepassivecheck.inc.php: $fh=fopen($tmpname.".ok","w+");
Yep, they do get recreated. Two new files for each check.ssax wrote:Can you delete those check files out of /tmp and see if they get recreated after you submit a check result.
No change in behavior, files still written to /tmpssax wrote:One test you might do after you've deleted them out of temp is to stop the nagios service and then submit the check through the NRDP interface and see if they show up in /tmp, /usr/local/nagios/var/tmp, or in /usr/local/nagios/var/spool/checkresults.
There is only one place that it can pull that file location from, it's defined in /usr/local/nrdp/server/config.inc.php and it's defined properly in yours.
Are these the temp files created from your manually entry through the NRDP web interface? If not, let's just focus on submitting through the NRDP web interface just for troubleshooting purposes.
Please post your /etc/httpd/conf.d/nrdp.conf
Yes, in these tests I've only been using the /nrdp/ web interface.
cat /etc/httpd/conf.d/nrdp.conf
<Directory "/usr/local/nrdp">
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# Allow from 127.0.0.1
# AuthName "NRDP"
# AuthType Basic
# AuthUserFile /usr/local/nrdp/htpasswd.users
# Require valid-user
</Directory>
Alias /nrdp "/usr/local/nrdp/server"Re: NRDP Config Problem
Let's see what NRDP is getting.
Edit /usr/local/nrdp/server/plugins/nagioscorepassivecheck/nagioscorepassivecheck.inc.php
Change line 134 from:
To:
Submit one and post the XML output.
Change the file back when done.
echo " <message>OK</message>\n";Code: Select all
echo " <message>OK ".print_r($cfg)."</message>\n";Change the file back when done.
<?xml version="1.0" encoding="utf-8"?>
<result>
<status>0</status>
Array
[authorized_tokens] => Array
[0] => xxxxxxx
[require_https] =>
[require_basic_auth] =>
[valid_basic_auth_users] => Array
[nagios_command_group] => nagios
[command_file] => /usr/local/nagios/var/rw/nagios.cmd
[check_results_dir] => /usr/local/nagios/var/spool/checkresults
[tmp_dir] => /usr/local/nagios/var/tmp
[product_name] => nrdp
[product_version] => 1.0
<message>OK 1</message>
<meta>
<output>2 checks processed.</output>
</meta>
</result>Re: NRDP Config Problem
So, I set up clean on a new Nagios core box and get the same behavior, files still written to /tmp/
Hmm, I'd like to lab this up.
What distro/version are you using, and is it full/minimal install?
What guide are you following (post a link) to install it or how exactly are you installing it?
I didn't set up either server but here is what I can tell you.
Box 1
Red Hat Enterprise Linux Server release 5.11 (Tikanga)
Nagios Core 4.0.2
NRDP 1.2
Apache/2.2.3
PHP 5.1.6
Box 2
Oracle Linux Server release 6.6
Nagios Core 3.5.1
NRDP 1.2
Apache/2.2.15
PHP 5.3.3
For comparison, the specs for the XI box that works as expected:
CentOS release 6.6 (Final)
Nagios Core 4.0.8
NRDP 1.3.1
Apache/2.2.15
PHP 5.3.3
For set up I'm following the instructions here http://assets.nagios.com/downloads/nrdp ... erview.pdf
Box 1
Nagios Core 4.0.2
NRDP 1.2
Apache/2.2.3
PHP 5.1.6
Box 2
Nagios Core 3.5.1
NRDP 1.2
Apache/2.2.15
PHP 5.3.3
Nagios Core 4.0.8
NRDP 1.3.1
Apache/2.2.15
PHP 5.3.3
