Instance status different in console and GUI
jolson
Attack Rabbit
Re: Instance status different in console and GUI
Post by jolson »
Thank you for that, much appreciated. Any chance that selinux is running on either server?
sestatus
If so, let's try turning it off temporarily and seeing if that helps:
setenforce 0
Let us know. Thanks!
Twits Blog
pccwglobalit
Post by pccwglobalit »
hi any updates on this? thanks
pccwglobalit wrote:hi any updates on this? thanks
Did you check the things in jolson's post?
pccwglobalit
all selinuxs are disabled.
jolson
Attack Rabbit
Post by jolson »
Okay, it seems we're at a point where basic troubleshooting isn't leading us down the correct path. I'll need some more information so I better understand your setup.
Some questions I'd like you to answer in a detailed way are as follows:
When was this NLS cluster installed and setup? Was it working previously?
When did this stop working and were there any events that led up to it?
It looks like commands from the WebGUI are not reaching the cluster. This can mean a variety of things, but I'd like you to try the following:
Make sure cron is running on every server:
systemctl status crond
Ensure that the nagios account isn't expired:
chage -l nagios
Report cron logs to ensure it's functioning:
tail -n20 /var/log/cron.d/log
Let me know. Thank you.
Twits Blog
pccwglobalit
we setup the NLS cluster on dec. it was working previously until we add nfs to server and change uid of nagios.
the crond is running
crond.service - Command Scheduler
Loaded: loaded (/usr/lib/systemd/system/crond.service; enabled)
Active: active (running) since Wed 2015-03-11 11:10:11 GMT; 1 weeks 4 days ago
Main PID: 8115 (crond)
CGroup: /system.slice/crond.service
__8115 /usr/sbin/crond -n
Mar 11 11:10:11 nls1-tmh2.it.pccwglobal.com systemd[1]: Started Command Sched...
Mar 11 11:10:11 nls1-tmh2.it.pccwglobal.com crond[8115]: (CRON) INFO (RANDOM_...
Mar 11 11:10:11 nls1-tmh2.it.pccwglobal.com crond[8115]: (CRON) INFO (running...
Mar 11 11:10:11 nls1-tmh2.it.pccwglobal.com crond[8115]: (CRON) INFO (@reboot...
Hint: Some lines were ellipsized, use -l to show in full.[/color]
chage -l nagios
the password is setup never expired
Mar 23 01:48:01 nls1-tmh2 CROND[31296]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Mar 23 01:48:01 nls1-tmh2 CROND[31297]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Mar 23 01:49:01 nls1-tmh2 CROND[31366]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Mar 23 01:49:01 nls1-tmh2 CROND[31367]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Mar 23 01:50:01 nls1-tmh2 CROND[31540]: (root) CMD (/usr/lib64/sa/sa1 1 1)
Mar 23 01:50:01 nls1-tmh2 CROND[31541]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Mar 23 01:50:01 nls1-tmh2 CROND[31542]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Mar 23 01:51:01 nls1-tmh2 CROND[31584]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Mar 23 01:51:01 nls1-tmh2 CROND[31585]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Mar 23 01:52:01 nls1-tmh2 CROND[31654]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Mar 23 01:52:01 nls1-tmh2 CROND[31655]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Mar 23 01:53:01 nls1-tmh2 CROND[31794]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Mar 23 01:53:01 nls1-tmh2 CROND[31795]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Mar 23 01:54:01 nls1-tmh2 CROND[31935]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Mar 23 01:54:01 nls1-tmh2 CROND[31936]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Updating Cluster Hosts File
Updating Elasticsearch with instance...
sudo: unknown uid 8005: who are you?
jolson
Attack Rabbit
Post by jolson »
Can you change the UID of nagios back to what it was originally as a test, and then restart elasticsearch and logstash?
usermod -u <UID> nagios
systemctl restart elasticsearch
systemctl restart logstash
Twits Blog
pccwglobalit
After change usermod, now seems working. will change another one and confirm the status. thanks for your help.
jolson
Attack Rabbit
Post by jolson »
No problem - I will wait for your confirmation before locking this thread. Thanks!
Twits Blog
