Interesting - it does look like a deeper problem. It looks like this is a manual build - is that correct? Any chance you could download the pre-compiled VM? I want to avoid as many potential problems for you as possible, and the VM is a surefire way to do so.
The first troubleshooting step we should take is tailing jobs.log - please run the following commands in the order specified-
Run tail on all of your nodes:
Running command apply_config with args 'a:2:{s:5:"sh_id";s:22:"OZejdfdfeqkXQ";s:10:"sh_created";i:14534306;}' for job id: dgLv1KasdfgX_qTzL7EQ
If you don't see any output in jobs.log, that means that jobs are not reaching your log server for some reason. We can troubleshoot accordingly once you have returned your output. Thank you!
TwitsBlog Show me a man who lives alone and has a perpetually clean kitchen, and 8 times out of 9 I'll show you a man with detestable spiritual qualities.
If you would like to start over, I recommend reformatting the device in question with a minimal CentOS 6/7 install. Instructions to install Nagios Log Server are as follows: http://assets.nagios.com/downloads/nagi ... Server.pdf
Could you perform the reinstall and let us know how it goes?
How was this server's OS installed? Clean, minimal install? GUI install? Was anything modified before installation of Logserver? Just trying to figure out what will need to be addressed, so more detail is better.
For the most part it is a clean MS Azure VM that had NRPE client installed for our core nagios instance to montior. I dont have full visablity on what other items were installed by our system support vendor.
Mar 20 10:55:01 az84implico13c crond[34981]: (nagios) FAILED to authorize user with PAM (Authentication token is no longer valid; new one required)
Mar 20 10:55:01 az84implico13c crond[34982]: (nagios) FAILED to authorize user with PAM (Authentication token is no longer valid; new one required)
Mar 20 10:56:01 az84implico13c crond[35285]: (nagios) FAILED to authorize user with PAM (Authentication token is no longer valid; new one required)
Mar 20 10:56:01 az84implico13c crond[35284]: (nagios) FAILED to authorize user with PAM (Authentication token is no longer valid; new one required)
Mar 20 10:57:01 az84implico13c crond[35345]: (nagios) FAILED to authorize user with PAM (Authentication token is no longer valid; new one required)
Mar 20 10:57:01 az84implico13c crond[35346]: (nagios) FAILED to authorize user with PAM (Authentication toke
Mar 20 10:58:01 az84implico13c crond[35385]: (nagios) FAILED to authorize user with PAM (Authentication token is no longer valid; new one required)
Mar 20 10:58:01 az84implico13c crond[35384]: (nagios) FAILED to authorize user with PAM (Authentication token is no longer valid; new one required)
Mar 20 10:59:01 az84implico13c CROND[35478]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Mar 20 10:59:01 az84implico13c CROND[35479]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Mar 20 11:00:01 az84implico13c CROND[35672]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www
