Need help with NRPE in nagiosXI:
Re: Need help with NRPE in nagiosXI:
Run the following two commands on the client (remote box) and show us the output:
ps axuw | grep nrpe
netstat -at | grep nrpe
How did you install NRPE (from repo, using our installer, etc.)?
Also, test your check from the command line (not in the CCM) from the Nagios XI server.
/usr/local/nagios/libexec/check_nrpe -H <client ip> -t 60 -c check_mountpoints
If it fails, run the commands below and show us the output:
nmap <client ip> -p 5666
shan_1986
Post by shan_1986 »
Below is the output from the remote box:
****@****:~$ ps axuw|grep nrpe
1411391397 20499 0.0 0.0 6504 624 pts/7 S+ 03:10 0:00 grep --color=auto nrpe
nagios 30035 0.0 0.0 39408 804 ? Ss Apr15 1:07 /usr/sbin/nrpe -c /etc/nagios/nrpe.cfg -d
****@****:~$ netstat -at | grep nrpe
tcp 0 0 *:nrpe *:* LISTEN
Here is the output from Nagios box:
NRPE is installed via repo.
[****@**** ~]$ /usr/local/nagios/libexec/check_nrpe -H **** -t 60 -c check_mountpoints
NRPE: Unable to read output
NRPE v2.12
[****@**** ~]$ nmap **** -p 5666
Starting Nmap 5.51 ( http://nmap.org ) at 2015-04-20 03:13 CDT
Nmap scan report for 192.168.18.102
Host is up (0.011s latency).
PORT STATE SERVICE
5666/tcp open nrpe
Nmap done: 1 IP address (1 host up) scanned in 1.97 second
It could be a permission problem for the check_mountpoints plugin. Try running the following to change the permission and owner of the file to see if that resolves it for you.
chown nagios.nagios /usr/lib/nagios/plugins/check_mountpoints
chmod a+rx /usr/lib/nagios/plugins/check_mountpoints
shan_1986
Post by shan_1986 »
I have tried modifying the permission but i'm getting the same error message while executing in CCM and from nagios server.
Is this a problem with ubuntu machine, the same plugin works well in Centos.
Please advise.
Run the following command on the remote Ubuntu box and show us the output:
su nagios -c '/usr/lib/nagios/plugins/check_mountpoints -A'
I believe you need to have the "utils.sh" file present in the "/usr/lib/nagios/plugins/" directory. Can you verify that you have it on the Ubuntu box. You may have it on the CentOS machine but not on the Ubuntu one...
ls -la /usr/lib/nagios/plugins/ | grep utils
