nrpe ssl
bbailey6
Re: nrpe ssl
Post by bbailey6 »
Right now I am testing nsclient on my Windows 7 machine but we have plans to install it onto Server 2008, all 64 bit. We are using an appliance as the Nagios server that came with check_nrpe installed.
Here is my Wireshark capture:
Heres the NSC.ini
[modules]
NRPEListener.dll
NSClientListener.dll
CheckWMI.dll
FileLogger.dll
CheckSystem.dll
CheckDisk.dll
CheckEventLog.dll
CheckHelpers.dll
FileLogger.dll
CheckSystem.dll
CheckDisk.dll
NRPEListener.dll
SysTray.dll
CheckEventLog.dll
CheckHelpers.dll
CheckWMI.dll
CheckNSCP.dll
; Script to check external scripts and/or internal aliases.
CheckExternalScripts.dll
; NSCA Agent if you enable this NSClient++ will talk to NSCA hosts repeatedly (so dont enable unless you want to use NSCA)
;NSCAAgent.dll
; LUA script module used to write your own "check deamon".
;LUAScript.dll
; RemoteConfiguration IS AN EXTREM EARLY IDEA SO DONT USE FOR PRODUCTION ENVIROMNEMTS!
;RemoteConfiguration.dll
; Check other hosts through NRPE extreme beta and probably a bit dangerous! :)
;NRPEClient.dll
; Extreamly early beta of a task-schedule checker
;CheckTaskSched.dll
[crash]
; Archive crash dump files if a crash is detected
archive=1
; Submit crash reports to a crash report server (this overrrides archive)
;submit=0
; Restart service if a crash is detected
;restart=1
[Settings]
;# OBFUSCATED PASSWORD
;  This is the same as the password option but here you can store the password in an obfuscated manner.
;  *NOTICE* obfuscation is *NOT* the same as encryption, someone with access to this file can still figure out the
;  password. Its just a bit harder to do it at first glance.
;obfuscated_password=Jw0KAUUdXlAAUwASDAAB
;# PASSWORD
;  This is the password (-s) that is required to access NSClient remotely. If you leave this blank everyone will be able to access the daemon remotly.
;password=secret-password
;# ALLOWED HOST ADDRESSES
;  This is a comma-delimited list of IP address of hosts that are allowed to talk to the all daemons.
;  If leave this blank anyone can access the deamon remotly (NSClient still requires a valid password).
;  The syntax is host or ip/mask so 192.168.0.0/24 will allow anyone on that subnet access
allowed_hosts=xxx.xxx.xxx.xxx,127.0.0.1/32
;# USE THIS FILE
;  Use the INI file as opposed to the registry if this is 0 and the use_reg in the registry is set to 1
;  the registry will be used instead.
use_file=1
password=*********
; # USE SHARED MEMORY CHANNELS
;  This is the "new" way for using the system tray based on an IPC framework on top shared memmory channels and events.
;  It is brand new and (probably has bugs) so dont enable this unless for testing!
;  If set to 1 shared channels will be created and system tray icons created and such and such...
;shared_session=0
[log]
;# LOG DEBUG
;  Set to 1 if you want debug message printed in the log file (debug messages are always printed to stdout when run with -test)
;debug=1
;# LOG FILE
;  The file to print log statements to
;file=nsclient.log
;# LOG DATE MASK
;  The format to for the date/time part of the log entry written to file.
;date_mask=%Y-%m-%d %H:%M:%S
;# LOG ROOT FOLDER
;  The root folder to use for logging.
;  exe = the folder where the executable is located
;  local-app-data = local application data (probably a better choice then the old default)
;root_folder=exe
[NSClient]
;  This is a comma-delimited list of IP address of hosts that are allowed to talk to NSClient deamon.
;  If you leave this blank the global version will be used instead.
;allowed_hosts=
;# NSCLIENT PORT NUMBER
;  This is the port the NSClientListener.dll will listen to.
;port=12489
;# BIND TO ADDRESS
;  Allows you to bind server to a specific local address. This has to be a dotted ip adress not a hostname.
;  Leaving this blank will bind to all avalible IP adresses.
;bind_to_address=
;# SOCKET TIMEOUT
;  Timeout when reading packets on incoming sockets. If the data has not arrived withint this time we will bail out.
;socket_timeout=30
[NRPE]
;# NRPE PORT NUMBER
;  This is the port the NRPEListener.dll will listen to.
port=5666
;# COMMAND TIMEOUT
;  This specifies the maximum number of seconds that the NRPE daemon will allow plug-ins to finish executing before killing them off.
command_timeout=60
;# COMMAND ARGUMENT PROCESSING
;  This option determines whether or not the NRPE daemon will allow clients to specify arguments to commands that are executed.
allow_arguments=1
;# COMMAND ALLOW NASTY META CHARS
;  This option determines whether or not the NRPE daemon will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow_nasty_meta_chars=0
;# USE SSL SOCKET
;  This option controls if SSL should be used on the socket.
use_ssl=1
;# BIND TO ADDRESS
; bind_to_address=
;  This is a comma-delimited list of IP address of hosts that are allowed to talk to NRPE deamon.
;allowed_hosts=
;# SCRIPT DIRECTORY
;  All files in this directory will become check commands.
;  *WARNING* This is undoubtedly dangerous so use with care!
;script_dir=scripts\
;# SOCKET TIMEOUT
socket_timeout=30
[Check System]
;# CPU BUFFER SIZE
;  Can be anything ranging from 1s (for 1 second) to 10w for 10 weeks. Notice that a larger buffer will waste memory
;  so don't use a larger buffer then you need (ie. the longest check you do +1).
;CPUBufferSize=1h
;# CHECK RESOLUTION
;  The resolution to check values (currently only CPU).
;  The value is entered in 1/10:th of a second and the default is 10 (which means ones every second)
;CheckResolution=10
;# CHECK ALL SERVICES
;  Configure how to check services when a CheckAll is performed.
;  ...=started means services in that class *has* to be running.
;  ...=stopped means services in that class has to be stopped.
;  ...=ignored means services in this class will be ignored.
;check_all_services[SERVICE_BOOT_START]=ignored
;check_all_services[SERVICE_SYSTEM_START]=ignored
;check_all_services[SERVICE_AUTO_START]=started
;check_all_services[SERVICE_DEMAND_START]=ignored
;check_all_services[SERVICE_DISABLED]=stopped
[External Script]
;# COMMAND TIMEOUT
;command_timeout=60
;allow_arguments=0
;allow_nasty_meta_chars=0
;# SCRIPT DIRECTORY
;script_dir=c:\my\script\dir
[Script Wrappings]
vbs=cscript.exe //T:30 //NoLogo scripts\lib\wrapper.vbs %SCRIPT% %ARGS%
ps1=cmd /c echo scripts\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
bat=scripts\%SCRIPT% %ARGS%
[External Scripts]
;check_es_long=scripts\long.bat
;check_es_ok=scripts\ok.bat
;check_es_nok=scripts\nok.bat
;check_vbs_sample=cscript.exe //T:30 //NoLogo scripts\check_vb.vbs
;check_powershell_warn=cmd /c echo scripts\powershell.ps1 | powershell.exe -command -
[External Alias]
alias_cpu=checkCPU warn=80 crit=90 time=5m time=1m time=30s
alias_cpu_ex=checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
alias_mem=checkMem MaxWarn=80% MaxCrit=90% ShowAll=long type=physical type=virtual type=paged type=page
alias_up=checkUpTime MinWarn=1d MinWarn=1h
alias_disk=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
alias_disk_loose=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ignore-unreadable
alias_volumes=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED
alias_volumes_loose=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED ignore-unreadable
alias_service=checkServiceState CheckAll
alias_service_ex=checkServiceState CheckAll "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
alias_process=checkProcState "$ARG1$=started"
alias_process_stopped=checkProcState "$ARG1$=stopped"
alias_process_count=checkProcState MaxWarnCount=$ARG2$ MaxCritCount=$ARG3$ "$ARG1$=started"
alias_process_hung=checkProcState MaxWarnCount=1 MaxCritCount=1 "$ARG1$=hung"
alias_event_log=CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1 "filter=generated gt -2d AND severity NOT IN ('success', 'informational') AND source != 'SideBySide'" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
alias_file_size=CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%" max-dir-depth=10
alias_file_age=checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%"
alias_sched_all=CheckTaskSched "filter=exit_code ne 0" "syntax=%title%: %exit_code%" warn=>0
alias_sched_long=CheckTaskSched "filter=status = 'running' AND most_recent_run_time < -$ARG1$" "syntax=%title% (%most_recent_run_time%)" warn=>0
alias_sched_task=CheckTaskSched "filter=title eq '$ARG1$' AND exit_code ne 0" "syntax=%title% (%most_recent_run_time%)" warn=>0
alias_updates=check_updates -warning 0 -critical 0
check_ok=CheckOK Everything is fine!
[Wrapped Scripts]
;check_test_vbs=check_test.vbs /arg1:1 /arg2:1 /variable:1
;check_test_ps1=check_test.ps1 arg1 arg2
;check_test_bat=check_test.bat arg1 arg2
;check_battery=check_battery.vbs
;check_printer=check_printer.vbs
;check_updates=check_updates.vbs
; [includes]
;# The order when used is "reversed" thus the last included file will be "first"
;# Included files can include other files (be carefull only do basic recursive checking)
; myotherfile.ini
; real.ini
[NSCA Agent]
;# CHECK INTERVALL (in seconds)
;   How often we should run the checks and submit the results.
;interval=5
;# ENCRYPTION METHOD
;   This option determines the method by which the send_nsca client will encrypt the packets it sends
;   to the nsca daemon. The encryption method you choose will be a balance between security and
;   performance, as strong encryption methods consume more processor resources.
;   You should evaluate your security needs when choosing an encryption method.
; Note: The encryption method you specify here must match the decryption method the nsca daemon uses
;       (as specified in the nsca.cfg file)!!
; Values:
;	0 = None	(Do NOT use this option)
;	1 = Simple XOR  (No security, just obfuscation, but very fast)
;   2 = DES
;   3 = 3DES (Triple DES)
;	4 = CAST-128
;	6 = xTEA
;	8 = BLOWFISH
;	9 = TWOFISH
;	11 = RC2
;	14 = RIJNDAEL-128 (AES)
;	20 = SERPENT
;encryption_method=14
;# ENCRYPTION PASSWORD
;  This is the password/passphrase that should be used to encrypt the sent packets.
;password=
;# BIND TO ADDRESS
;  Leaving this blank will bind to "one" local interface.
; -- not supported as of now --
;bind_to_address=
;# LOCAL HOST NAME
;  The name of this host (if empty "computername" will be used.
;hostname=
;# NAGIOS SERVER ADDRESS
;  The address to the nagios server to submit results to.
;nsca_host=192.168.0.1
;# NAGIOS SERVER PORT
;  The port to the nagios server to submit results to.
;nsca_port=5667
;# CHECK COMMAND LIST
;  The checks to run everytime we submit results back to nagios
;  Any command(alias/key) starting with a host_ is sent as HOST_COMMAND others are sent as SERVICE_COMMANDS
;  where the alias/key is used as service name.
[NSCA Commands]
;my_cpu_check=checkCPU warn=80 crit=90 time=20m time=10s time=4
;my_mem_check=checkMem MaxWarn=80% MaxCrit=90% ShowAll type=page
;my_svc_check=checkServiceState CheckAll exclude=wampmysqld exclude=MpfService
;host_check=check_ok
;# REMOTE NRPE PROXY COMMANDS
;  A list of commands that check other hosts.
;  Used by the NRPECLient module
[NRPE Client Handlers]
#check_other=-H 192.168.0.1 -p 5666 -c remote_command -a arguments
;# LUA SCRIPT SECTION
;  A list of all Lua scripts to load.
;[LUA Scripts]
;scripts\test.lua
Reason: [code] wraps save scroll wheels :)
Re: nrpe ssl
Thanks for the info! I just tested the "use_ssl=1" option in NSClient++ ver. 0.3.9 on Windows 7 64-bit machine and it worked as expected. I didn't see any clear text - it was all encrypted.
I am not sure why it is not working for you. Try stopping/starting the NSClient++ service or maybe even reinstalling it. I used the msi installer for 0.3.9 64-bit:
http://files.nsclient.org/legacy/NSClie ... .9-x64.msi
If this doesn't help, you can try stopping the service and starting it in a test mode as administrator.
net stop nsclientpp
cd "c:\Program Files\NSClient++"
nsclient++ /test
Search the output for NRPE/encryption errors.
mp4783
Re: nrpe ssl
Post by mp4783 »
Have you considered the NCPA client. According to Nagios documentation, it is the recommended agent for Windows. It has the advantage that it can function both as an active and passive agent. It also has some really cool real time performance graphs.
The other major advantage is that it is, in theory, available for all platforms, making it a universal agent. I've only just started to explore it myself. To the best of my knowledge, it can run any plugin and in that respect makes it equivalent to NRPE.
The final advantage is that it was developed by Nagios, making integration (in theory) tighter.
Re: nrpe ssl
Thanks, mp4783!
@bbailey6
NCPA is indeed a very cool agent. You can use either NSClient++ or NCPA - it's your choice. However, if NSClinet++ is not working for you, I would give NSCA a try. You can do "regular", most common active/passive checks, and run custom scripts with it as well. Let us know if you have any more issues/questions.
http://assets.nagios.com/downloads/ncpa/download.php
bbailey6
Re: nrpe ssl
Post by bbailey6 »
I thought NSCA was only the client sending passive checks? I'll look into it a bit more.
I was really trying to get the Windows agent working just like the Linux one so we could be streamlined across all our servers. I'm going research your findings lmiltchev and see what I can find. If that's a dead end, I'll check out the NSCA client.
Re: nrpe ssl
Sounds good! Keep us posted. I will keep this topic open for a while in case you have more questions/issues. Thanks!
bbailey6
Re: nrpe ssl
Post by bbailey6 »
I'm gonna spin up a VM and test the nsclient you posted. I uninstalled what I had here on my test machine and installed the one you linked but im still getting plaintext. I've uninstalled and installed so many different versions. Gonna try a clean slate
bbailey6
Re: nrpe ssl
Post by bbailey6 »
hey lmiltchev,
how are you running your wireshark? I am running it with host=nagios ip and I get the cleartext but when I run tcp port = 5666 I get a capture but its all garbage. im not a wireshark expert so I thought I would ask how you are using it.
thanks
edit: Hm ok well, I ran a straight wireshark capture with no filters, I was just quick about my business so I didn't have to pilfer through too much data but I still did find clear text requests from nagios and clear text responses from my host. back to my vm idea :)
cmerchant
Re: nrpe ssl
Post by cmerchant »
It might be easier to use tcpdump to capture from the command line of the Nagios XI server and take the pcap file and open it within wireshark. Here is the tcpdump command I have used successfully.
tcpdump -nnXSs 0 -w /tmp/snmp.pcap 'port 5666'
run that for awhile and [CTRL]-C to end the capture.
You can also PM your pcap file to us, and we can look at the capture file as well.
bbailey6
Re: nrpe ssl
Post by bbailey6 »
OK so I spun up a brand new host. I grabbed windump.exe and modified the command a little to run under windump on windows. The command I am running is windump.exe -nnXSs 0 -w c:\temp\snmp.pcacp port 5666
I ran that with ssl=1 and then I commented out the line ";use_ssl=1" and ran it again and called that one .pcap1
Currently downloading wireshark so I can examine both files!
edit: OK well that didn't work so well. I can open both files and every single packet is garbled. I searched high and low for the string "cpu" and "alias" in all the packets but I couldn't find anything.
edit2: ok well, ran regular non-filtered wireshark test on my test machine and got the clear text output. Ran the same exact test in my vm of win7 and I don't see any clear text. I am a bit baffled at this. I can only assume that I hosed my test machine by installing/uninstalling all different kinds of versions of nsclient and nscp. Maybe something got stuck in the registry and followed all my different installs? I have no clue.
I wonder if I am running some kind of web server or service on my test machine that I don't know about that is trumping the ability to use ssl? Ever heard of anything like that? I use this machine for all kinds of testing so I knew when I ran into troubles, I would have to spin up a VM.
Anyone heard of another program inhibiting the use of ssl with nsclient? I'm hoping this rings a bell with someone because this is kinda crazy.
