Could you guys help me in debugging it, I am brand new to shell scripting. Could you help on picking the error. or there is any tool online which helps in " debugging the script file"? Please help me
check_tftp code below:
STATE_OK=0
STATE_WARNING=1
STATE_CRITICAL=2
STATE_UNKNOWN=3
STATE_DEPENDENT=4
function print_version () {
cat <<EOF
check_tftp 1.0.1 - Copyright Mathias Kettner ([email protected])
This Nagios plugin comes with no warranty. You can use and distribute
it under terms of the GNU General Public License Version 2 (GPL V2) or
later. You find a copy of the GPL V2 in the source code of this script.
EOF
function print_copying () {
EOF
function print_help () {
print_version
cat <<EOF
This plugin checks the accessability of a TFTP server. The TFTP
"Trivial File Transfer Protocol" is mainly used for supplying kernel
images for clients booting from network.
check_tftp has two levels of test: First it can test if it is
possible to connect to a TFTP server at all by asking for some none
existant bogus file and checking the negativ answer from the
server. Use the option --connect to select this kind of operation.
Second it can try to actually retrieve a certain file, whose name you
have to specify. The file is really transmitted so you rather would
like to choose a small file for regular checks.
Note: TFTP uses UDP not TCP. The tftp client from H. Peter Anwin tries
25 seconds the get an answer to its UDP packages from the TFTP server.
If the TFTP service is not running this check will return a CRITICAL
state no sooner than after a delay of 25 seconds!
EOF
print_usage
cat <<EOF
Options:
-h, --help
Print detailed help screen
-V, --version
Print version information
--connect HOST
Tries to connect to tftp service on host HOST and retrieve
a bogus dummy file. The server must answer with Error code 1:
File not found in order for the check to succeed.
--get HOST FILENAME SIZE
Tries to actually retrieve the file FILENAME from host HOST.
The file is stored in a temporary directory and deleted afterwards.
In order for the check to succeed the fetched file must exactly
have the size SIZE.
The FILENAME must not contain any white space characters!
EOF
function print_usage () {
cat <<EOF
Usage: check_tftp -h, --help
check_tftp -V, --version
check_tftp --connect HOST
check_tftp --get HOST FILENAME SIZE
EOF
function check_principal_errors () {
case "$1" in
*:" unknown host")
echo "Unknown host $HOST"
exit $STATE_DEPENDANT
*"Transfer timed out.")
echo "Transfer timed out"
exit $STATE_CRITICAL
esac
function check_connect () {
HOST="$1"
RESULT="$(echo get NaGiOs_ChEcK_FiLe | tftp $HOST 2>&1 | head -n 1)"
check_prinzipal_errors "$RESULT"
case "$RESULT" in
*"Error code 1: File not found")
echo "OK - answer from server"
exit $STATE_OK
echo "$RESULT"
esac
function check_get ()
HOST="$1"
FILENAME="$2"
SIZE="$3"
SIZE=$(( SIZE ))
TMPDIR=/tmp/check_tftp
mkdir -p "$TMPDIR"
cd "$TMPDIR" || { \
echo "Cannot create temporary directory in /tmp"
exit $STATE_UNKNOWN
RESULT="$(echo get $FILENAME | tftp $HOST 2>&1 | head -n 1)"
if [ -f "$FILENAME" ] ; then
ACTSIZE="$(wc "$FILENAME" --bytes | awk '{print $1;}')"
else
ACTSIZE=0
fi
rm -f "$FILENAME"
cd ..
rmdir "$TMPDIR"
check_principal_errors "$RESULT"
case "$RESULT" in
echo "Server answered: file $FILE not found"
*"Received "*" bytes in "*" seconds")
if [ "$SIZE" -ge "$ACTSIZE" -a "$SIZE" -le "$ACTSIZE" ] ; then
echo "OK - ${RESULT#*tftp> }"
exit $STATE_OK
else
echo "File size mismatch: expected $SIZE bytes, got $ACTSIZE bytes"
fi
echo "$RESULT"
esac
case "$1" in
--help|-h)
print_help
exit 0
--version|-V)
print_version
exit 0
--connect)
if [ "$#" != 2 ] ; then
print_usage
exit 5
fi
check_connect "$2"
--get)
if [ "$#" != 4 ] ; then
print_usage
exit 5
fi
check_get "$2" "$3" "$4"
print_usage
exit 5
esac
