SNMP checks timing out
Re: SNMP checks timing out
For the check_snmp command, the community string setting should be a capital -C try changing the command to
/usr/local/nagios/libexec/check_snmp -H server -P 2c -C community -t 30 -o 1.3.6.1.4.1.9.9.109.1.1.1.1.6.1
Post by Box293 »
Good spotting Tom.
It's confusing when check_snmp and snmpget have different arguments.
OptimusB
Post by OptimusB »
Good find and thanks! This worked. I guess the others that I have configured work because those devices were using public as community string. so -c public was not working but it used the default public community string. Gave it the illusion that the check arguments are working.
# /usr/local/nagios/libexec/check_snmp -H <IP> -P 2c -C <Community> -t 30 -o 1.3.6.1.4.1.9.9.109.1.1.1.1.6.1
SNMP OK - 14 | iso.3.6.1.4.1.9.9.109.1.1.1.1.6.1=14
jdalrymple
Skynet Drone
Post by jdalrymple »
Awesome! Did that solve all your issues then, OK to lock and mark solved?
OptimusB
Post by OptimusB »
Yes. Thanks and lock!
