Configurating Quick Actions ( Action Component )
Re: Configurating Quick Actions ( Action Component )
Post by Box293 »
I can't resist commenting ... when you're getting up to 90+ Quick Actions ... it would take me a while to find the one I'm after :lol: :lol: :lol:
monitoreo1
Post by monitoreo1 »
:lol: :lol: :lol: :lol: :lol: ok......i can't upgrade the component because that configuration is in the production enviroment....
i have to prepared a test enviroment for replicate the 91 commands :( :( :(
please if you have news soon.... share them us.
thanks for your help !!!!
ssax
Dreams In Code
Post by ssax »
I was not able to replicate the issue on my end, I experienced no limit and it allowed me to add more.
Do you see all 90 of them in there or is any of it getting cut off?
Please run the command below and then PM me the /tmp/actions_output.txt file:
echo "select * from xi_options where name = 'actions_component_options';" | psql nagiosxi nagiosxi > /tmp/actions_output.txt
monitoreo1
Hi !!!
Yesterday, i sent a PM with the requested file.
What version of "Action Component" dou you have?
Thanks for your help !!!!
ssax
Dreams In Code
Post by ssax »
I am running 1.5.5 on XI 2014R2.6.
I'll import yours and see if I can replicate it, I'm wondering if one of the actions that you had could have been causing the issue, hopefully it wasn't one of the 16 your removed otherwise I might not be able to reproduce it.
I'll let you know shortly.
monitoreo1
ok.....thanks for your help !!!!!
ssax
Dreams In Code
Post by ssax »
I'm unable to replicate the issue when importing what you provided, I have no cutoff at 90.
The only way that we can try to fix it is to replicate it, we would need you to reproduce the issue and send us the data or pull the data from a backup and send us that output.
What browser are you using?
monitoreo1
I think that the problem is not generated in a specific "action command", because when we was programming the "91" command, we had to erase another command ( the less important for the configuration enviroment ), and then ,we installed succesfully the initial command ( the "91").
We use the Chrome and Firefox.
Thanks for your help.
ssax
Dreams In Code
Post by ssax »
Zip up your /usr/local/nagiosxi/html/includes/components/actions directory and PM it to me so that I can take a look at it, thanks!
monitoreo1
Hi again !!!
We are using more "Actions Command" !!!!
At the moment we have used 72, do you have found something in the files that we shared the last week ?
