NRPE on Solaris9
ssax
Dreams In Code
Re: NRPE on Solaris9
Post by ssax »
Please PM me your acl.c file.
Edit: Received file, placed in shared support directory.
maddev
Post by maddev »
sent you.
jolson
Attack Rabbit
Post by jolson »
I was looking for solutions to your issue, and came across a solaris agent:
cd /tmp
wget http://assets.nagios.com/downloads/nagiosxi/agents/solaris-nrpe-agent.tar.gz
tar xzf solaris-nrpe-agent.tar.gz
cd solaris-nrpe-agent
./fullinstall
This may only work for Solaris 10+, but I figured I would throw this procedure your way since it's quite simple and may resolve the problem.
Twits Blog
maddev
Post by maddev »
Hi Jolson,
It did not work on Solaris 9. I tried with that already. Event went to modify the script to identify the machine as solaris 9. But no luck.
Best way would be to figure out the problem with compiling on solaris 9. Or to make someone compile on a solaris9 machine and to get the binary.
abrist
Red Shirt
Post by abrist »
Have you checked: https://www.opencsw.org/ for any potential packages?
maddev
Post by maddev »
yup. But no luck.
What they have is also for Solaris 10
jdalrymple
Skynet Drone
Post by jdalrymple »
Solaris 10 is still supported, Solaris 9 is not as of last year.
I compiled a more time-period appropriate version of NRPE on Solaris 9 - it went fine:
bash-2.05# uname -a
SunOS unknown 5.9 Generic_118559-11 i86pc i386 i86pc
bash-2.05# ./nrpe
NRPE - Nagios Remote Plugin Executor
Copyright (c) 1999-2007 Ethan Galstad ([email protected])
Version: 2.10
Last Modified: 10-19-2007
License: GPL v2 with exemptions (-l for more info)
SSL/TLS Available: Anonymous DH Mode, OpenSSL 0.9.6 or higher required
** POSSIBLE SECURITY RISK - COMMAND ARGUMENTS ARE SUPPORTED! **
**      Read the NRPE SECURITY file for more information     **
** POSSIBLE SECURITY RISK - TCP WRAPPERS ARE NOT AVAILABLE!  **
Usage: nrpe [-n] -c <config_file> <mode>
Options:
 -n            = Do not use SSL
 <config_file> = Name of config file to use
 <mode>        = One of the following two operating modes:
   -i          =    Run as a service under inetd or xinetd
   -d          =    Run as a standalone daemon
Notes:
This program is designed to process requests from the check_nrpe
plugin on the host(s) running Nagios.  It can run as a service
under inetd or xinetd (read the docs for info on this), or as a
standalone daemon. Once a request is received from an authorized
host, NRPE will execute the command/plugin (as defined in the
config file) and return the plugin output and return code to the
check_nrpe plugin.
maddev
Post by maddev »
Hi jdalrymple,
Thank you very much. I was able to compile and install the version 2.1 of NRPE.
Now comes the next part of establishing comminucation; I am seeing ssl handshake error. hope some of the below information is helpful.
On the solaris 5.9 node
uname -a
SunOS <hostname> 5.9 Generic_112233-11 sun4u sparc SUNW,UltraSPARC-IIi-cEngine
cat /etc/services | grep -i nrpe
nrpe    5666/tcp                                #NRPE
ps -ef | grep -i inet
    root 23787 19129  0 00:48:26 pts/2    0:00 grep -i inet
    root 23593     1  0 00:39:27 ?        0:00 /usr/sbin/inetd -s
netstat -a | grep -i nrpe
      *.nrpe               *.*                0      0 49152      0 LISTEN
lsof -i:5666
COMMAND   PID USER   FD   TYPE        DEVICE SIZE/OFF NODE NAME
inetd   23593 root   68u  IPv4 0x37ed007b528      0t0  TCP *:nrpe (LISTEN)
pkginfo -l | grep -i ssl
   PKGINST:  RHATossl
      DESC:  The OpenSSL toolkit.
   PKGINST:  RHATpossl
      DESC:  Python wrapper module around the OpenSSL library
   PKGINST:  SMCossl
    VENDOR:  The OpenSSL Group
egrep -v "^#.*$|^$" /etc/nagios/nrpe.cfg
log_facility=daemon
pid_file=/var/run/nrpe.pid
server_port=5666
nrpe_user=nagios
nrpe_group=nagios
allowed_hosts=127.0.0.1,<ip.of.my.nagios.xi.machine>
dont_blame_nrpe=1
debug=0
command_timeout=60
connection_timeout=300
include=/etc/nagios/nrpe/common.cfg
cat /etc/inet/nrpe
        # default: on
        # description: NRPE
        service nrpe
                flags           = REUSE
                socket_type     = stream
                wait            = no
                user            = nagios
                server          = /usr/local/nagios/bin/nrpe
                server_args     = -c /usr/local/nagios/etc/nrpe.cfg --inetd
                log_on_failure  += USERID
                disable         = no
                only_from       = 127.0.0.1 <ip.of.my.nagios.xi.machine>
/usr/local/nagios/libexec/check_nrpe -H localhost
CHECK_NRPE: Error - Could not complete SSL handshake.
/usr/local/nagios/libexec/check_nrpe -H localhost -n
CHECK_NRPE: Response packet had invalid CRC32.
From my Nagios XI server
/usr/local/nagios/libexec/check_nrpe -H <ip.of.solaris9.machine>
/usr/local/nagios/libexec/check_nrpe -H <ip.of.solaris9.machine> -n
ssax
Dreams In Code
Post by ssax »
Looks like your /etc/inet/nrpe is pointing to the wrong config file:
Should be:
server_args     = -c /etc/nagios/nrpe.cfg --inetd
Or was that a posting mistake?
/etc/init.d/inetsvc stop
/etc/init.d/inetsvc start
maddev
Post by maddev »
No good; still the same error. :(
