as pnp4nagios do generate the graph of my script?
alexprinou
Re: as pnp4nagios do generate the graph of my script?
Post by alexprinou »
dear friend I have that same script running on other equipment along with the nagios he creates the txt file normally. when I put the script on other equipment that I want to monitor him from the uknow error.
Post by Box293 »
Does the other equipment have correct directory permissions that allow the nagios user to create / update a file in that location?
What happens when you test the script as the nagios user?
su nagios
./check_your_plugin blah blah blah
alexprinou
thank you friends got was even x permission in directory
Post by Box293 »
Is your problem now resolved?
alexprinou
Re: Nagios will not return string from bash script
dear friends to this forum helped me solve my problems I decided to post my code
I hope it helps more people
# bash -x check_ccq_estacao_tx_router
cd /home/nagios
rm -rf ccq-tx-estacao.txt
outputSSH=$ ssh [email protected] "/interface wireless monitor 0 once"|grep tx-ccq|sed 's/%//' > ccq-tx-estacao.txt
output=$(sed 's/tx-ccq://g' ccq-tx-estacao.txt)
if [ $output -ge 85 ] ; then
   echo "$output % | ccqtx=$output"
   exit 0;
elif [ $output -le 85  ]; then
   exit 2;
else
   echo "$output"
   exit 1;
fi
exit 3;
abrist
Red Shirt
Post by abrist »
Thanks for the update!
