host in 2 groups with clashing service checks - overwrite ?
stucky
Re: host in 2 groups with clashing service checks - overwrit
Post by stucky »
btw. just to mention..it appears both the service name _and_ service description need to match for nagios to consider this the same service.
jdalrymple
Skynet Drone
Post by jdalrymple »
Hmmm...
That's not the behavior I get:
        host_name                       localhost
        service_description             PING
        use                             local-service
        display_name                    This is one service
        check_command                   check_ping!100.0,20%!500.0,60%!!!!!!
        register                        1
        host_name                       localhost
        use                             local-service
        display_name                    And this is another
        check_command                   check_dummy!2!!!!!!!
        register                        1
