Windows check to check space on all disks
jdalrymple
Skynet Drone
Re: Windows check to check space on all disks
Post by jdalrymple »
jkinning wrote:Well, not sure what happened but I added the
[/settings/NRPE/server]
use ssl = 1
payload length = 1024
allow nasty characters = false
allowed ciphers = ADH
ssl = true
allow arguments = 1
insecure = true
to my nsclient configuration file on the Windows server which I am running 0.4.3.77 version of the nsclient++ and getting CHECK_NRPE: Error - Could not complete SSL handshake.
Feel free to undo anything I tell you to do if it breaks your system :)
I was just sharing with you the config options that work on mine. If were getting good results from nsclient & check_nrpe then there is no need to change those bits of the config.
