NCPA Agent log errors
jwuerflein
Re: NCPA Agent log errors
Post by jwuerflein »
Thanks. Yes, seems like its working now... wondering about log and log rotation and size. Hopefully the rest can be fixed and is more cosmetic.
You could put these 2 lines back in the config file. I was checking to see if the error would change or go away.
logmaxmb = 20
logbackups = 10
ssax
Dreams In Code
Post by ssax »
Those directives will work properly, I just validated on my machine.
I looked in the code and I see what is happening, basically the code says:
"Hey, get me all the commands from the config file under the section 'passive checks'"
For whatever reason it's returning the commands under the passive checks section like it's supposed to but is also including the information under the passive section were those directives are set and it's trying to process them as commands and of course they aren't.
You can safely ignore those errors.
